4.3/V8 swap?
Discussion in 'The Garage' started by CHEVY 4WD, Apr 9, 2005.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    OK I have a new frame I was gonna build up excally the way I want it and stick my body on it (but keep the 350 and 700R4 untill I have enough $$$ to build a BBC and 4L80E) the frame had a 4.3 in it origionally but I though they were the same excact frames and motor mounts am I wrong? the only reason Im ask now is someone cut part of the engine crossmember with a torch like they were trying to clearance it (they guy I bough it from was going to put a SBC in it too). BTW this is a K10 LWB
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    good question im not sure but i know of a 4.3
    86 or so full size truck i can look at if needed,
    i bet at least the block mounted brackets differ from v8 ones
    probably
    but enigne mounts i dunno, call local parts store and compare them
    good luck
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    should be identical, although you may have to move them forward or back.
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    should be identical or pretty close to it... If that frame is anything like the one on my bros jimm its gonna be a tight fight... doable but a PITA if it has a s-10 body. the firewall is your biggest problem with that combo.
    like beater k20 said you'll probably have to move the motor mounts around to get it to fit right.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its a k-10 long wheelbase
    not an s-series heh
    good luck
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Yea its a fullsize... I always though they were identical (thats why Ive been saving this frame) but I was just going to check with the experts :D before I start striping this and paying for powdercoating :crazy:
  7. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    no one is 100% sure if they are the same or what has to be done? :confused:
  8. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    give me 5 min to call my bro... i'll find out.
  9. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    i don't think you have to change a thing to drop a SBC, should fall right in to stock frame mounts.....
    P.S. where in Fl. you at man, i live in Ocklawaha just east of Ocala.
    I drive a 18 wheeler OTR and get home every 2 weeks, maybe we can hhok up and do some wheelin...check out the website for pics of my radical 4x4
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    here's an idea... measure from the rear most motor mount hole to the belhousing flange. post up the measurement, and someone here can measure a smallblock.
  11. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    im up for some wheelin but im a little ways away... Ft Myers wich is about 20min north or Naples. Good to see another FL CK5er though I think theres only about 5 of us
