4.3L/350tbi Swap Problem
Discussion in 'The Garage' started by trukman1, Mar 5, 2004.
  1. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Posting for a friend: He has a '94 350tbi w/ dual exhaust, new wires, plugs, cap/rotor, etc. in'94 S-10 originally 4.3L. Problem is at idle the engine loads up after 15-30 seconds but runs good at higher RPM. Any suggestions? BTW, he is using the ECM from the 4.3L. Thanks for the help...Gary /forums/images/graemlins/1zhelp.gif
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I'm no expert but shouldn't the computer make a difference? Try the ECM of a v-8 /forums/images/graemlins/k5.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you could use the eCM of a 5.7L with same tranny from a caprice or camaro or full size truck, etc. whichever you can find with same tranny model and same engine as you have now and same fuel system type
    i woudl check temp sensors, O2 sensor, Map sensor, and TPS, and clean the IAC real good and the cavitiy it threads into out too
