4.3L and an Impco 425...
Discussion in 'The Garage' started by sled_dog, Aug 16, 2006.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Think a 425 is too much for a stock(to be modded) 4.3L? Seriouslly considering grabbing a junkyard 4.3L for my S10 and already have a brand new 425 for my propane setup. future plans would be bored out and cammed or maybe turbo(in which case a 425 would make plenty of sense).
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sled, search around over at www.austink5.com There are a few guys on there that drive bunsen burners. ;)
  3. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    haha, yea, quite a few guys know alot about propane over there.
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I dont know about propane setups, but I know a properly modded 4.3 can put out some insane numbers for a 6 cylinder.
  5. mrk5
    Apr 20, 2004
    12,331
    1,040
    Northern Colorado
    I've been checking out propane kits on gotpropane.com and I saw this:
    Looks to me like you'd be okay.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    If the 425 is to much then I have a 225 that would work for ya. A 225 is to big for a 22re so I am assuming it would be good on jeep type motors. So the 4.3l might fall into that slot.
  7. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    This will tell what you want to know.
    CID * RPM / 3456 * 0.85 = CFM required
    425 flows 460 cfm max
    262.5 * 7000 / 3456* 0.85 = 452 cfm required
    carb size formula LINK
    So you will be good to over 7000 rpm
    Over carbing it should just make it burn rich. Shouldnt hurt power output. It just wont burn all of the propane.
    On my truck it was either be under carbed or over carbed with the 425's. I went with 2 just to make sure there was enough power.
    Here are some other good propane links.
    http://franzh.home.texas.net/engine.html
    http://www.dualcurve.com/home.htm
    http://www.patooyee.com/ (Go to the technical section and click on Propane)
    http://www.wps.com/LPG/index.html#INDEX
    www.propaneguy.com (where I got all my stuff)
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Yeah thats part of what the problem is. I'm going to finish my 383. Big issue for me is my 383 is the same boat as your 400. Its either going to be under or overcarbed. Oh well. I am just not looking forward to the cost of another 425, 2 Model E regulators, 2 carbs for their bases, dual carb intake, and the linkage/lines to make everything work. Oh well, it ought to run like a raped ape when all is said and done.
  9. mrk5
    Apr 20, 2004
    12,331
    1,040
    Northern Colorado
    gotpropane.com sells a kit for "big blocks and hot small blocks" that flows better than the Impco 425.
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    The X450 mixer. Try finding a new one. I'm buying all new components for my system(no messing with rebuilding or hoping things arne't worn out). THey however do not flow THAT much more air than the 425 does. Forget what the comparison specs are. Besides which, $1100??? I'll have less than that into my dual carb setup with tanks! And all BRAND NEW Impco stuff.
  11. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    Where to buy parts?
    Can you let us in on where you are buying your new parts? It looks like I fall in with some of you on whether the 425 would be enough - 350 bored .030 over running a mild cam and currently topped with a Q-jet.
    Thnaks, Ronnie
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Ebay man. Bought from a couple places so far. All I have at the moment is one 8 gallon fuel tank, my 425, and a VFF30 Lockoff. Lockoff and Mixer are brand new.
