4.5" backspace on wheels work for 10 bolt?? (im a moron)
Discussion in 'The Garage' started by XHitman396, Jul 26, 2006.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    so this is about the 4-5th post of mine on the subject... sorry.. I was in the process of buying the wheels i want, come to find out they only come in one 'option' with an 8-lug; and it's a 15x8 cragar black steel rim, with 4.5" backspacing. will that backspacing be able to fit up front with the 10 bolt without shaving the calipers?? if not, how much do i have to shave off?? is that amount safe?? are there wheel spacers available to space it out more if i don't wanna shave the calipers?? thanks, and sorry for the repetition..
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    on a 10b calipers don't get in the way 4.5" backspacing will work
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    You will have to grind on the backing plates on a 3/4 ton 10b. The calipers might need a smoothing, but nothing much. I have pics at home of how much I had to grind the back plates. I will post them up if i remember.
  4. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    Ya, you will need to grind a little bit. Its not that big of a deal. Just put a mask on so your not blowing out black snot for a day or two!
  5. XHitman396
    May 3, 2002
    620
    alright, you talked me into it.. if it ain't much i guess ill order 'em.. thanks again..
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Here are the pics
