4:56---3:08 carriers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAROLINAK5, Nov 23, 2001.
  1. CAROLINAK5
    CAROLINAK5 1/2 ton status
    Aug 2, 2001
    242
    lexington, north carolina
    can i use the same carrier for both? i have a 14 ff and a 10 blt. any ideas or advice.
    what gear brand do ya'll recommend? do we have a discount to any of the offered gears?
    when all else fails..............HIDE!!!!!!!!!!!!!!!!![​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/albun32>http://coloradok5.com/gallery/albun32</a>
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    If you haev a 14 FF with 3.08 now and you want to upgrade to 4.56 you need to get the "thick" ring set. The carrier will only work up to 3.73. I would slap on a set of genuine gears from 4wpw. They sell the "thick" set.
  3. Grim-Reaper
    7,385
    Atlanta
    I think you can get the thick ring set up to a 4.10. After that you need to change to a series 4 carrier that will handle 3.73 up on the 12 bolt and I think on the 14 it's 4.10 up.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  4. CAROLINAK5
    Aug 2, 2001
    242
    sorry, but i forgot to add that the 14 bolt has 3:73 in it now....the 10 bolt has the 3:08.
  5. Grim-Reaper
    7,385
    Atlanta
    The 14 should work. The 10 will need a new carrier. to big of a jump from 3.08 to 4.56.
    75 Jimmy, Dollar
    Grim-Reaper
  6. CAROLINAK5
    Aug 2, 2001
    242
    how much do carriers run? any brand better than the other?
  7. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Carriers???
    What??? Explain to me please what a carrier is? I went from 3.08-4.56 , the shop did it but never said anyhtign about a carrier? Also go to www.drivetrainwarehouse.com they sell genuine gear for cheap. I bought 2 sets of 4.56 and 2 install kits that run about 50-80 by themselves. For 400 total free shipping. It was a good deal imo
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    In desperate need of a rebuild.
    Next- Eaton mech locker... Flows.
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Just track down a junkyard that has one. That will definetly be your cheapest route.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Find a 3/4 ton 10 bolt in the junkyard. It'll already have a 4.10 ring and pinion, and carrier, most likely.
    Tim
  10. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    YOU DONT NEED A CARRIER. The case brake for a 10 bolt is 2.73 and down and 3.08 and up.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  11. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    or you if you find a 12 bolt front you'll be good as gold j/k
    hola
  12. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    The 10B uses the same carrier from 2.73:1 &amp; up (numerically, as in 4.88 or 5.57). Your 3.08 carrier is good for 4.56 gears. The other carrier is for 2.43-2.56. If you had one of these odd balls then go to the junkyard and get the other one. BTW, anyone wonder what that 5.57:1 10B R&amp;P looks like?
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
