4.56 and 35's need help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gill, Aug 9, 2001.
  1. gill
    gill Registered Member
    Aug 3, 2001
    37
    memphis and murfreesboro, tn
    4.56 and 35\'s need help
    Need help with my 88 blazer, planning on putting 4.56 gears in it this weekend myself, i have never done this before and was wanting some helpful knowledge, tips, ideas, criticism, or someone in the memphis, tn area that wouldnt mind helping out. any info would help and the best place to buy the gears and what kind of installation kits i will need to put them in does anyone have gears from 4wpw they have the lifetime warranty so if i screwed it up i could take them back no ?'s asked and also will i need any special tools?
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Re: 4.56 and 35\'s need help
    4WPW Did The 4.56s And Lockers On My 82. They Will Not Warranty These Gears With 35 Inch Tires.I Would Not Attempt To Replace Them Myself . If They Are Not Set Right You Will Destroy Them Real Quick . Also They Will Not Warranty For Improper Setup If You Do It Yourself. So I Did It The Easy Way And Let 4WPW Do The Work.
    A Big Hammer Can Fix Anything ..
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Replacing gears is a long, tedious, and tough task for someone who hasn't done it before. I am kinda refreshing myself on it as it has been since tech school since I've setup a rear. Unless you can do dang near anything on your truck it may be time to farm that job out. That or try and find some axles for sale w/ the gears you want
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have done a lot of research on this. As far as installing them, I wouldn't do it yourself. If your gears fail due to installation, you may have to fight about that warranty. And, even if they did cover it, you don't want to be sitting disabled because your diff just grenaded. The going rate around here is about $300 per axle install. You might be able to find a mechanic in your area through here or a friend that would do it cheaper and let you help so you learn. That's what I am doing.
    As far as where to buy, I shopped around a lot and found I got the best service and information from <a target="_blank" href=http://www.ring-pinion.com>Randy's Ring &amp; Pinion</a>. They really knew there stuff about which was best and what all you need (install kits and such). I just got a set of 4.56s, two install kits, and two Detroit Lockers from them last week.
    Good luck!
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    PM me for a great deal on blinker fluid! Best price on the net!
  5. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    i spent 13hrs. doing mine and the next week i spent 1300.00 to have them all redone, leave this to the experts!
  6. gill
    Aug 3, 2001
    37
    thanks alot for the info i think yall helped me make my mind up about what i want to do
