4.56 and 35's???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AK-5GUY, Feb 24, 2003.
  1. AK-5GUY
    AK-5GUY Registered Member
    Apr 24, 2002
    89
    Greensboro, North Carolina
    4.56 and 35\'s???
    I have a 1987 blazer with a tbi 350 and 700R4. I am about to buy a 14 bolt ff with 4.56's and hope to put 35's on it soon. My front axle is a 10 bolt with 3.42's. If anyone has a 10 bolt front for sell with 4.56's for around 200 I will take it (will pay shipping).
    My question is: I will be using this truck as a daily driver back and forth from highschool, and also for some short four wheeling trips (around 60 highway miles or so). Will the 4.56's and 35's be an economical combination in town? Will they be economical on the highway? I understand that they will have a lot of power, but will they be overkill for in town driving, and/or highway? I will run 35's for a while untill I can afford 37's or so along with my insurance, maintainance, and school. How will 37's and 4.56's do also?
    Any information will be greatly helpful. Thanks.
    Harrison
  2. AK-5GUY
    Apr 24, 2002
    89
    Re: 4.56 and 35\'s???
    Also, will I have to replace the carrier on the front 10 bolt with 3.42's to put in 4.56's myself? Thanks
    Harrison
  3. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i am running 35s and 456s with a turbo 400 and i dont like it as far as having to drive it everyday.. i would go to 410s if you plan on it being your daily driver.. and also you will need a different front carrier for the 456s.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You should be fine. I am running 32's and 4.56's right now. With the carb 350 & 700R4 I get decent economy on the highway, and a little worse around town. I wouldn't go with any less gear then 4.56's if you have a 700R4. With the OD & 35's you will turn 2100ish at 65 most likely. I turn 2600 at 65, and as long as I don't push it up past that much I get 10-12 mpg. My truck only got 13 on highway with 3.73's so I only lost 1-2 mpg, but when I get my 35-37's I will get some of that back probably.
    Intown you will hurt a little more, but it isn't terrible.
  5. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im running 36's and 4.56's and I love it. Ive also got a 700r4. I almost wish I has gone 4.88's.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ya, I am thinking the same thing. When I get my 37's (a long way away) I will be back to almost stock gearing. If the 10bolt front would take 4.88's (it will, but the pinion gets really small) and I had it to do over I would go 4.88's or 5.13's.
  7. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I get 18mpg (highway) with tbi350/700/4.56/35'' and it is tolerable on the highway if you don't plan on going fast /forums/images/graemlins/wink.gif. As for the front carrier, there is only 1 carrier break in 10 bolts and it is something like 2.73-down and 3.08-up so no you DO NOT have to change carriers, I swapped the 3.42's in my front 10bolt to 4.56's with the same carrier and they were NOT thick gears /forums/images/graemlins/thumb.gif
  8. AK-5GUY
    Apr 24, 2002
    89
    Well it sounds like a good choice to go with the 4.56's with the 700R4. Thanks a lot guys.
    Hey, does anyone have a front 4.56 8 lug axle for around 200 so i dont have to do the ring and pinion myself? /forums/images/graemlins/wink.gif Almost sounds to complicated to me! Thanks
    Harrison
  9. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I wouldn't suggest doing it yourself unless you're very mechanically inclined. Its a touchy process and if you mess it up or do it wrong... say bye bye to your ring*pinion maybe more.
  10. AK-5GUY
    Apr 24, 2002
    89
    Yeah, that's what I was thinking. Now all I need to do is find a 4.56 8 lug front axles for 2-300. HMMM /forums/images/graemlins/confused.gif
    harrison
  11. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    it would be a good choice, i am considering doing this to my 88, especially since you have the 700 with the overdrive, all 10 bolt with the 8.5 inch ring gear use the same carrier from 2.73 and up, so you will not need a new carrier unless you want a full case locker like arb or detroit; you can use the same carrier and use a lock right or e-z locker /forums/images/graemlins/thumb.gif
  12. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    You can find just the front huds from about 150 and up or hit the local junk yards and look for a 3/4 ton 8 lug and just bolt it in. But then it will be hard to find one with 4.56's So you mite have to wait around the for sale area and someone mite have one.
    Didn't you say you we're in High school? Are you taking Auto Shop? That would be a great shop project.
    Eric
  13. AK-5GUY
    Apr 24, 2002
    89
    I wanted to take auto shop untill I found out that they were not going to offer it any longer! /forums/images/graemlins/shocked.gif
    I'll look around on here for the front. Let me know if you guys find what im looking for. Thanks for all the help.
    Harrison
  14. new2k5
    new2k5 1/2 ton status
    Dec 16, 2002
    128
    south eastern PA
    it would be easier but more expensive to find a 60 with 456's thats what i'm puttin in mine
  15. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    Ive had 4.56s, 35s, and a 700r4 for years now, works great. RPMs on the freeway arent to bad with OD. Unless you like to drive ur rig 95 mph all the time, I'd go 4.56 if I was you.
    j
