4.56 carrier for 14b
Discussion in 'The Garage' started by BigOrange90Jimmy, Aug 19, 2002.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    do i have to buy a new carrier to run this gear ratio? current is 3.73.
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    It really depends on the gears. Some aftermarket manufacturers make thicker low ratio gear sets to fit high ratio carriers to prevent having to buy a different carrier (I have thick 5.13's on a 4.10 carrier in my truck). If they are OE GM 4.56's you will have to buy the correct carrier because GM doesn't make them like that.
  3. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    darn, that sucks. that's what i'm bidding on Ebay, and they are factory gears. where could i get the factory carrier?
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    yup /forums/images/icons/grin.gif sorry /forums/images/icons/frown.gif 4.10 is the break
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You can buy thecarrier from any of the major drivetrain places. When I was looking for one Drivetrain Direct had the best price at $189.</font color>
  6. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Order the 'thick' 4.56's. They make a gear set that comprimises for the difference in the carriers.
  7. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    so what are you saying? i could use the factory carrier and order the thick gears, or just thick gears for a 4.10-up carrier?
  8. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    You said you were bidding on a set of OE gears on Ebay, right? Do one of these two things :
    1) use your 3.73 carrier and buy thick aftermarket gears
    2) buy the gears off of Ebay and buy a 4.56 &amp; up carrier from someone like Drivetrain Direct.
    Go with which ever is best for your wallet, the result is the same.
  9. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    well really what would be good for my wallet is if the 4.56's would fit the stock carrier. which of the two listed options is the cheapest?
  10. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    The thick gears would be better on your wallet.
  11. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    where's a good place to get them? well, maybe uglychevy383 will sell me his carrier if it'll work.
  12. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i need to figure out a weight of a 14ff carrier though... anyone know?
  13. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    As to which is cheapest, that just depends on what you pay for the Ebay gears.
  14. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    right now i'm looking at 53 bucks + ride for the ebay gears
  15. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    If you found the thicker gears that cheap, id go that routte! shipping you a 14ff carrier will be spendy i bet..
  16. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    really they're the factory 4.56's
  17. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I got Motive Gears from Napa. I don't remember how much though. I want to say the part number for the thinner 4.56's were the same as the thick 4.56's only the thick ones had an "x" on the end....I think.../forums/images/icons/crazy.gif
    Talk to the parts stores in your area and get quotes. Or, if you have a brand you want, I'm sure they have a website. With gears, you get what you pay for. You'll want to break them in properly too. You can overheat the oil if you just start driving on them like normal. When the oil breaks down, then your new gears could get ruined.
    Breaking in new gears
  18. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Napa sells gears!? That's almost like Advanced selling new parts. But I'll check around. Thanks for the tip.
  19. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    [/ QUOTE ] that is correct, Id just go to 4 wheel parts wharehouse.
