4.56 Gears swap in 14 bolt, Do I have to change carrier or not????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Waxer, Jul 7, 2000.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I currently run 3.73's with a Detroit in my 14 bolt.. Attached is a scan of the 14 bolt page in 4 wheel parts wholesalers, I circled in yellow a note that states the thick gears will work in the lower ratio carrier. So does that mean I wont have to change to the high ratio carrier if I want 4.56's?? Thanks....
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I am putting 5.13 gears in my 14 bolt ff. according to randy's ring and pinion, reider racing, west coast differentials, the 3.73- 4.56 carrier is the same. I am using a 3.73 carrier. the 3.42 carrier is the one you can't use. I have never seen a 3.42 carrier!!!!
    your right. I don't understand the jeep thing!
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Well, this is what I heard. The carrier needs to be changed if you are going with a 4.11 and higher. A 4.10 and lower carrier will not work unless you get the thicker Ring. But they do sell the thicker ring and pinion set where you can use the lower geared carrier they sell it at http://www.macromotive.com they explaine the differences just shop for gear ratios for the 14ff
  4. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    If you have a 3.73- 4.10 carrier you will need the thick cut
    ring gear for your 14 bolt for it to work, unless you get a
    4.56 and up carrier. Been there and done that. You will love
    the new gears. There bitchin!!
    MUDNUT
