4:56 Gears
Discussion in 'The Garage' started by 87blues, Jun 2, 2005.
  1. 87blues
    87blues Registered Member
    Jun 2, 2005
    24
    Virginia
    I have a 87 GMC Jimmy that I would like to put some 4:56 gears in the front and rear along with dtroit lockers in the rear because I have a 4" susp lift with 35's. What do I need to have this done as in the gears, install kit, and case?
  2. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
  3. 87blues
    Jun 2, 2005
    24
    Virginia
    Thax for the site. That is some good reading for sure. I have someone that will install everything on the side for me, I just really need to know what to order so the installation can be done.
  4. RustyParts
    May 26, 2005
    235
    Wyman, Kentucky
    I don't know what gear ratio you have now, but if you have 3:73 or less you will have to buy a new carrier assembly for the front (if it's a GM) and since your changing to a locker on the back they parts dealer can match that up for you.
    Two installation kits.
    Two sets ring and pinion
    One posi unit (for rear)
    One Carrier assembly for front. If your present one is a GM.
  5. 87blues
    Jun 2, 2005
    24
    Virginia
    I'm not sure myself the ratio now, but it is stock. It is a GM front so thanx for letting me know about the carrier I will need to buy as well as the posi unit. I did not know about those items. Any recommend good sites to shop and find out the carrier type I'll need?
  6. RustyParts
    May 26, 2005
    235
    Wyman, Kentucky
    Here's the outfit I buy from they have comparable prices and a knowledgable staff with quick delivery.
    http://www.yukongear.com/
    Good luck!
  7. 87blues
    Jun 2, 2005
    24
    Virginia
    A friend told me about this forum, but I did not realize it would be so helpful. Thank you very much RustyParts.
  8. RustyParts
    May 26, 2005
    235
    Wyman, Kentucky
    We can all use a little help from time to time.
    Git er done!!!
