4:56 in 10bolt, or 6 lug with 4:56
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by emoo99, Apr 21, 2003.
  1. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    ok i'm having a little decision problems,, first off i'm planning on some 35's in the near future so i want to go with a 4:56 ratio.. i can buy a new set of gears for the front and rear with a limited slip for $875.. OR i can just get a 14BB 6 lug (don't want to buy new rims) with 4:56 in them.. i'm thinking buying the whole new axles would be cheaper and probably stronger but what kind of truck do i look for that's a 6 lug with 4:56's in them?
  2. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    You won't find them unless someone has changed the gears. You can look for a 3/4 ton that came equipped with the 6 cyl. They usually had 4:56 gears. Although they would be 8 bolt. You could change the front to the 6 bolt set up and buy some 8 to 6 bolt adapters for the rear from echobit. /forums/images/graemlins/usaflag.gif
