4.56 or 4.88 gears?
Discussion in 'The Garage' started by BlitzK5, Apr 3, 2007.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Need to now which gears to go with. I have 38" super swamper radials, 14 bolt in back in and a 10 bolt up front for now untill I get a Dana 60. Im running a 454 and a Th350. Im also looking at getting the black box and a NP205 from northwest fabrications so I will have a 5.33:1 low gear in the transfer case. Im thinking that I could go with 4.56 since I will get a good low range with the T-case and have lower rpms at highway speeds + since I got a 454 it would make up any lost torque from not going with 4:88's or lower. In the futrure I might go to 40's or 42's aswell but thats not untill I got a Dana 60 up front. What to you guys think would be the best for my setup? Im also not sure if 4.88 would be stong enough in a 10 bolt since the pinion would be so small. Is this a concern or would the axles and u-joints always go before the pinion?
  2. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    X2!!!!!!!!!!!!!!!!!!!!!!
  3. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I have 4.56s for a 10 bolt and 14FF if you're interested. They are used.
  4. BlitzK5
    Jul 29, 2005
    288
    How much? Free:). I live in Edmonton alberta Canada so shipping cost might be a few bucks.
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im going to be running a similar setup. im going to be running 4.56's with 42's and dual t-cases with an overdrive tranny. granted im running a diesel, at 65mph my rpms are going to be at 1850 which is the best for a diesel, while having a crawl ratio of 145, it should work out perfect.
    if you are going to be driving the truck on the highway alot w/o overdrive, id go 4.56. if you plan to ever get an od tranny, id go with 5.13's. if its going to see limited highway driving and mostly trail/town id go 5.13's. uve got a bbc so youll have the power to turn them with 4.56's
  6. Elroy303030
    Elroy303030 1/2 ton status
    Sep 25, 2006
    114
    Branson, Mo.
    How much do you want for them? What is shipping to 65616?
  7. guz71
    guz71 1/2 ton status
    Sep 17, 2006
    387
    lubbock/houston
    I have 38's and 4.56's with a 700r4. I just have 350 tbi and in OD the truck just puts along at 70-75. If there is a lot of head wind I have to slow down to 65 or less otherwise the tranny will just shift in and out of 3rd. in 3rd gear at 70 i have plenty of grunt so im sure you will be fine with the 454.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I would stay tall on the gearing (i.e. 4.56) since you are going have all the slow-speed gearing you need going dual cases.
  9. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    x2 bro
  10. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    if you go with 4.56 gears you can find a 60 later that already has matching gears.
    I would go with 5.13's or even 5.38's if you are considering regearing. you can never have too much gear,
  11. BlitzK5
    Jul 29, 2005
    288
    Yes thats what I was thinking as well. Its just finding a 60 is the hard thing let alone matching gears
  12. Stump-a-holic
    Stump-a-holic Registered Member
    Mar 21, 2006
    29
    South Wales, NY
    Im running 4.10's with my 454/T350 and 38.5's. On the street its fine. Offroad I only really do mud so the 2:1 low on the 203 is adequate. But I have a 4.56 matching D60 and 14B that Im looking to swap in for a bit more grunt and acceleration.
  13. Teamstatic2001
    Teamstatic2001 Registered Member
    Dec 24, 2005
    92
    Muskegon, MI
    Not to highjack to far but I got a d60 and 14 im regearing 454/700r4/208. Ive heard 5.13 are weak and twist pinions off. You guys think that will be a problem with a 14 and d60.
  14. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Elroy, I sent you an e-mail. Make pms available, it is easier to communicate that way here.
  15. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I would do whichever is cheaper cause the difference between 4.88s and 4.56s is not much. With a 454 I would probably go with the 4.56s because the motor has enough torque to deal with less than ideal gears.
  16. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Here's the analysis for you (your BEFORE and AFTER scenarios).....
    Courtesy of CrawlCAD (coming soon for a download near you!) :D
  17. BlitzK5
    Jul 29, 2005
    288
    WOW, now that's a program. When will it be available and were can I download it from? Thanks for putting in so much effort. But I don't see why your using 5.04 for the TH350. It has a first gear of 2.52
  18. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I just wrote that program yesterday.....sort of in response to all the questions I keep seeing about axle re-gearing and doublers/ aftermarket cases (Blackbox, STaK and Atlas).
    The program has pulldown menus for each blue square, so far the options are:
    Transmissions:
    TH350
    TH400
    700R4
    4L80E
    NV4500 (5.61)
    NV4500 (6.43)
    T-56
    Transfercases:
    NP203
    NP205
    NP208
    NP241
    LoMax NP205
    NWF BlackBox
    STaK 5.44
    ATLAS 5.44
    ATLAS 10.34
    Tire Diameters:
    33" through 54"
    The idea is to just select the driveline setup you currently have in the upper part, then build your "experimental" rig in the lower part. It should become obvious whether your parts selections make sense based on your objectives...
    In your case, the deeper axle gears are not going to do all that much for your crawl ratio in the second scenario.....the "doubled-up" transfercases are where the REAL reduction is happening. The engine RPMs at highway speeds should be your guide also. I'm not sure if you're running 3.73s now or 4.10s, but anything much deeper than that and you're going to start punishing yourself on the highway.
    My advice is to start your build plan with the tire diameter you know you want, and the highway RPM you want to run. Everything else can be worked backwards from that. If you don't have an OD tranny, you will use taller axle gears and a deeper set of gears in the transfercase. If you have an OD trans, you can run the deeper axle gears and less reduction in the transfercases...
    BTW -> It's not a typo, the TH350 uses a 2.52:1 first gear.....I multiplied that by the stall effect of the torque converter (generally accepted as a 2:1 ratio) which results in the 5.04 number you see there. The program is smart enough to know which transmissions are automatics and which are manual, and only applies that extra correction factor for the automatics.
    Glad you like the program! It will be posted up on www.gregblanchette.com probably early next week, since I'm taking off today for the Easter weekend.
    :usaflag:
  19. BlitzK5
    Jul 29, 2005
    288
    ok Thanks, I never herd about the stall effect thing before and that it give you a added 2:1 gear reduction. Can you explain further on this effect.
  20. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    The torque converter allows for slippage between the engine and tranny below it's rated "stall" RPM. When you start out at low RPM, the torque converter starts to move but there is not a 1:1 relationship between the engine RPM and with the input side of the tranny. As the RPMs build and the TC reaches it's stall speed, there is virtually no slippage....so the engine RPM is basically the same as the RPM on the input side of the trans. At that point, whatever "gear" you've got (in the case of the TH350 it's 2.52:1) is what you're ACTUALLY getting out the back of the transmission.
    So in effect, below the stall speed the transmission is slipping at about 50% which is why you use the "stall effect" multiplier of 2:1.
    Manual guys don't get that benefit, which is why you'll almost always see their trannies using a much deeper 1st Gear ratio than the slushboxes to compensate.
