4.56 or 4.88?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CarolinaBogger, Sep 27, 2001.
  1. CarolinaBogger
    CarolinaBogger Registered Member
    Apr 17, 2000
    86
    Boone, NC
    I know some of yall have some experience with this: I am planning on putting some 38"s on and was wondering which gears would be better: 4.56 or 4.88's. I have 4.10's with my 35"s and like that setup. One guy told 4.88's would be better. I have the stock 350 TBI. I am concerned about over-working the transmission with 4.56's. What do yall think?l
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    What tranny are you running? Also what axles are you running? If you have a 700r4 or 460LE tranny then I would reccomend the 4.88s. But if you are still running your 10 bolts front and rear you dont want to go any bigger than 4.56s. The reason is if you any bigger than 4.56s in a 10 bolt, the pinion gets too small and is very easy to break.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. CarolinaBogger
    Apr 17, 2000
    86
    Boone, NC
    I'm running a 700 tranny and a 12 bolt 8.875" rear and the stock 10 bolt front. I've heard the same thing about the small pinion vulnerability, but is the 12 bolt 4.88 pinion a lot stronger?
  4. The85k5
    The85k5 1/2 ton status
    Feb 22, 2001
    259
    Sunnyvale,Ca
    hey when you pop out those 4:10's u wanna sell em? cuz i'll buy them!!!! 3:08's and 35's just aint cuttin it
    Damn curbs always hitting em...oh wait that was a car?
  5. CarolinaBogger
    Apr 17, 2000
    86
    Boone, NC
    Sure, but there is a small chip on the reverse side of a tooth. It's never given me any problems though. Remember, it is out of a 12 bolt. I also have a 10 bolt 3.73 r&amp;p that is only about 8 months old.
  6. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    The 12 bolt pinion is stronger, but dont go any bigger than 4.88 with a 12 bolt.
  7. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    I'd go 4.88 with the 700R4. You have the overdrive to keep revs down &amp; the lower gearing will give you better starting power to get those big tires rolling.
    Just make sure you're sticking with the 700R4. I bought a D60/14 with 4.88's to go with a 700R4 &amp; in the end; I got a TH400 w/out OD so now my gears are a little high but still ok!
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  8. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have 4.56s with 35s and a 700. I am very pleased. But I would recommend 4.88s with your 38s and the 700.
    Brian
    A new day.... May God be with us all.
    <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Tribute</a>
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd go 4.88 or lower. I'd consider going lower anyway.
    Tim
