4.56 ratio 14-bolts: $200 each
Discussion in 'Pacific Region' started by mountainexplorer, Jan 22, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    ALL SOLD
    14-bolt Full-Floater 3/4 ton rear, 4.56 open, spring pads and shock mounts set up to bolt into a '69-'72 K5 Blazer or truck. Complete drum to drum. $200
    1974 14-bolt Full-Floater 1-ton Cab and Chassis Dually rear end, 4.56 open, complete drum to drum. Under 80,000 original miles out of motorhome. $200
    14-bolt Full-Floater 1-ton single wheel rear end, 4.56, out of 1981 Crew Cab, under 35,000 original miles behind a 292 6-cyl, complete rear axle drum to drum $200.
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    doesn't the 1 ton and the 67 to 72 have the same spring pad spacing?
    so basicly the 3/4 ton rear had em changed to fir the 67 to 72?
    I may need one these just need to take someome into giving me some front 456's to match,LOL.
  3. mountainexplorer
    Nov 14, 2001
    4,903
    Basically, all three have the same spring perch measurements. They should all bolt up (as far as spring perches go) into all 67-72's and 73-87 1-tons. In order for any to bolt under a '73-up 3/4 or 1/2 ton the spring perches would have to be moved.
    I had gotten the one for my '72 Jimmy, but I might just leave the Eaton rear in it if I sell the 14-bolt.
  4. Danny Joe
    Danny Joe 1/2 ton status
    Feb 10, 2005
    134
    Blythe,California
    Wish you were closer!
  5. smalltowncowboy
    smalltowncowboy 1/2 ton status
    Jan 16, 2006
    503
    hermiston oregon
    72 blazer
    i would buy the one for the 72 blazer but strapped for cash right now, in the process of buying a 72 K/5 and still need to go to kellogg to pick it up. if you know anyone interested in a 14SF i got one not sure on the gears in it.
    too many projects :doah:
