4.56 vs 4.88
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big83chevy4x4, Feb 3, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ok what gear retio should i go with? im stuck between the two. im going to be runnin 350/465/205 d60/14bff and 37s or 39s maybe 40s
    im thinking 4.65 because i don't have overdrive, and i have creaper but then 4.88 sound better i dunno /forums/images/graemlins/dunno.gif
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Try this Link
    Bill
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Well, sence you have a sm465, I would say go with the 4.56's if you ever drive on the highways, if it's a off road only vehickle, then think 5.13's
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    4.88's
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive tried the calculaters but cant deside what rpm i want replies that have had the 4.56 and with they had 4.88 or vice versa
    this thing is going to be a all around vehicle mud, sand, rocks, street, snow. probably more mud, sand, and snow than street and rocks. it is going to be driven to wheeling spots
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    I prefer 4.88 for tires in the 39" and 40" range.
    4.56 would work better for the 38" and shorter range especially with overdrive.
    Then 5.13 would be best left for 42" and larger tires. /forums/images/graemlins/thinking.gif
  7. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    My preferences for a street driven daily driver with overdrive.
    3.73 to 4.11 ---> 33s
    4.11 to 4.56 ---> 35s
    4.56 to 4.88 ---> 37s
    My preferences for a daily driver without overdrive.
    3.73 ---> 33s (still hi RPM at upper speeds)
    4.11 ---> 35s
    4.56 ---> 37s
    if you are not daily driving and going to 40s one day I wouldn't consider anything below 5.13s.
    But, you might not like what other people swear by.
    The BEST advice I can give you is be honest with yourself about what is important to you. If you must have the best offroad equip at the sacrifice of on-road drivability then go to a lower gear. If you are driving this thing on the road 99% of the time then you'll hate the lower gears unless you have deep pockets and really enjoy the high rpm motor. Which, you should get a cam that has a cruise rpm to match what you are running. The % in each environment is the important deciding factor.
    It is better, IMHO, to make one drivable with the gears and then later get lower transfer case gears to get a better crawl ratio. That way you have the best of both worlds.
    All that said, if you are running in the mud you'll want to stay on the taller side so you can get some tires spinning faster. In the rocks, on the lower side.
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have the sm465 np 205 14ff dana 60 4:10 combo and 38's and if i had the money id do it right the first time and go with 5:13's you plan on 39.5's or 40's so i would go with atleast 4:88's /forums/images/graemlins/thumb.gif
