4.56 with 39's ????????
Discussion in 'The Garage' started by funkycold, Aug 4, 2003.
  1. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    4.56 with 39\'s ????????
    I currently have 36" tires on my Suburban and 4.56 10 bolt. I have a 14FF 4.56 on the way. Will the 4.56 be adequate enough for the 39's I have waiting to go on or would it be best to go to 4.88 or 5.13. I mostly use it for DD but get offroad every once in a while.
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Re: 4.56 with 39\'s ????????
    It all depends on what your engine can handle.
    I'm running 4:10's with 39.5"s
    How? I have an engine with 345Hp & 500 ft-lbs of torque, and I manage to get somthing called 'mileage' b/c its not revving to hell on the highway.
    Addition: I also run dual transfers, So i can crawl aswell.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what tranny? i will be running 42+ and 4.10. BUT with a SM465. and some day a doubler.
    if i ever get the rest of the rig done....
    Grant
  4. funkycold
    Apr 22, 2002
    435
    Orange County, CA
    tranny...700R4
    currently run at 2400 rpm at 75 mph.
    8" lift, 10 bolts 4.56, 36" tires.......for now
  5. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Answer: yes the 4.56's will be adequate enough for the 39's and 700. Now on the other hand if there is the slightes chance in your mind that you might go bigger tire size, then I would definitly give it some serious thought to putting 5.13's in your axles.
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    5.13's. i've made this argument many times
  7. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Ive got 4.56's now with my 36's and when I go to bigger tires the 5.13's will go in also.
  8. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    tranny...700R4
    Big Block, or small block?
    If your revs are at 2400... they are going to drop even more with the 39's. Sounds good initially, but I wonder where your engine's peak torque is developed? If you're way under the powerband the motor is going to be WAY inefficient and your mileage will reflect that.
    Also, I'm not sure how much "hunting" your 700R4 will be doing with that setup. You may find your truck dropping out of O.D. a lot....
    I've heard the 4.56 gearsets described as the "orphan child" of the chevy gearset series. A little bit too agressive for the 31-33 inch crowd, and not quite deep enough for the 36"+ crowd....
    Then again, who am I to talk....I currently run 4.10s on 38.5"s.... /forums/images/graemlins/shocked.gif
  9. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Zakk, there are drivetrain combo's that don't need to be that deep with 39.5's. 4.56's are ideal for my truck...6.2 diesel and SM465.
    2600 rpm at 65 mph...I could honestly use overdrive for freeway, but it keeps up with traffic just fine. Ideal rev's for the 6.2 would be closer to 2000 (torque peak)
    Rene
  10. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I run 4.56s with a 700 tranny and 42" TSLs. I do not use OD. If I were to drive the rig everyday, I would say that they aren't enough gear for that big of tire, but I bet they would be fine for 39s. My engine puts out plenty fo power (400+ HP, 450+ torque), but the weak link becomes the tranny. I will someday decide on the cost of a doubler versus 5.13s, but it is fine for me for now.
    My guess is you will be okay running 4.56s with 39s. Just don't hesitate to run in D if OD doesn't feel right. Costs the same to swap gears later as it does before, just more downtime. Something you might want to consider.
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Sounds good if you've got a doubler. Also good if you need to run a smaller tire at times, like a 35 for everyday driving and 40 for the trail.
  12. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    I run 4.56's with my 700r, but if I could, I would do 4.88's or 5.13's. It's nice on the hiway, but everyone knows that running much over 75 mph is not safe in a rig that is lifted. I am guilty also.
    But, back to my point...You have overdrive and if you are going to stay with a 700r then go with something higher than 4.56's. BUT, if you plan on going to a T400, T350 or a manuel, then you need to stay with what you are planning to do. Specially if it is you DD like mine.
    I was cruising back from Windrock in Tn. @ 75 and got 16+ mpg.
    Future plan...
    And that is all I have to say about that. /forums/images/graemlins/thumb.gif
  13. funkycold
    Apr 22, 2002
    435
    Orange County, CA
    tx, being i do use my sub everday would you feel that i would lose anything by driving around in D vs.OD. only to put it in OD on the freeway vs. around town? and is the 14FF going to make any difference in this vs. 10 bolt?
  14. funkycold
    Apr 22, 2002
    435
    Orange County, CA
    Thanks Greg, i guess i will have to try it and see how it works before spending any money that i may not have to spend.
    Thanks for the /forums/images/graemlins/1zhelp.gif
  15. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    I have the 4.56 and 39.5 ratio and sm465. I also have a modified 402 big block crate motor. It is fine for driving, and stuff, and mud, but anthing other than that (trails, rocks, HILLS), it's way too high. I am going to switch to the th400/np203/np205 combo, and see how it is then. If it still is too high, then I'll get 5.13's. I also plan to switch to 42's in the mean time.
    I think youre big problem is going to be keeping that 10bolt from braking.
    Zakk... how many MPG do you get? I don't have an odometer/speedo, so I have no clue as to mine.
  16. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    It should work ok, the biggest thing you might have problems with is your crawl ratio off-road.
