4:56's too low for street?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jtpepper, Sep 22, 2002.
  1. jtpepper
    jtpepper Registered Member
    Jun 4, 2002
    43
    LOCKHART,TEXAS
    4:56\'s too low for street?
    I just shelled the pinion in my 10 bolt and I'm thinking of going to 4:56's.My ? is; are the 4:56's too low for the street and what rpm will I be turning?My set-up is as follows;83 Jimmy,350/700r4,10 bolts,33" bfg's.Will be going to 36" later on.Any help is greatly appreciated.GOD Bless,jtpepper
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    Re: 4:56\'s too low for street?
    <font color="blue">It might be a littler higher on the highway (personally I like it a little extra RPM to help push these barn doors rolling on huge heavy tires), but tollerable. You will definetly want the 4.56s with the 36" tires
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im gonna be running 4.56's and 36" tsl's. Highway with a 700r4 should be about 2200rpms
  4. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    yes, go with the 4.56's on the street with the 36's.
  5. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    yeah i have 36s and i have a set of 4.56s in my closet ready to install, i can't wait.
  6. jtpepper
    Jun 4, 2002
    43
    LOCKHART,TEXAS
    Thanx guy's.I forgot to mention that it is NOT a daily driver.Strictly play toy,(huntin' buggy).I was thinkin' it would be alright especialy since my engine is built for max power from 1800-6500 rpm's.Should be a big change from the stock 3:42's that are in it.I might be able to white smoke em'.Whataya' think? GOD Bless,jtpepper
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You might want to reconsider that gear ratio in a 10 bolt axle. 4.56's in a 10 bolt make the pinion gear pretty small and ready to explode at any given time. Just my $.02
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Good point, that is pretty much getting to the limit of a C10 pinion...
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Depending on how much you're willing to spend, 4:88's in a 14 bolt FF and Dana 60 with 38" tires sounds like alot of fun to me.
  11. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i've been running that gear for about two months now and love it. i cruise around 2200 rpm in over drive at 70mph and it wonderful. i wouldn't say its too low at all.
  12. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    4.56 in a 10 bolt is pusshing the strength a ways in my opinion....
    It'll probably be fine... lotsa guy's here run it i'm sure... But it's gotta weaken, or thin, the gears...
  13. chevrolet21
    chevrolet21 Registered Member
    Dec 21, 2001
    59
    WARNER ROBINS, GEORGIA
    i RUN 4:88'S IN MY 10 BOLT WITH 39.5 TSL'S FOR THE LAST YEAR AND HAVE NO PROBLEM. i'M NOT OUT ROCK CRAWLING OR ANYTHING THOUGH. IF YOUR CAREFUL YOU'LL BE JUST FINE
  14. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    [/ QUOTE ] Smokin' 36's with a set of 4.56's in a 10-bolt is a sure-fire recipe for disaster. /forums/images/icons/shocked.gif /forums/images/icons/frown.gif But then, I'm the guy that busted a couple of teeth off of a 3.42 pinion behind the weak 4.3L V6 in my S-Jimmy, on 30x9.50's. /forums/images/icons/shocked.gif You'll be able to see the difference in the beef of the pinion once you have the 4.56's next to the 3.42's. Years ago I had a '77 K5 with a 12-bolt running 4.10's and 35's that got lit up rather frequently. I broke teeth off of the ring gear 3 times in 3 years. Guess why I put a 14-bolt under the next one I bought! /forums/images/icons/wink.gif
