4-6 inch raised steering are on 2.5 lift? NOT GOOD
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DuneRunner, Mar 24, 2002.
  1. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    OK for the past week and a half I have had a 4-6 inch raised steering arm on my K5 that is raised 2.5 inches. and it is probably one of the scariest things driving NOW. Has anyone ever done this? I have figured out what I believe to be the problem.
    The raised arm hits the Draglink (I think thats what its called) (adjustable threded arm that connects to the Pitman arm) Well when I hit a bump the new arm comes in contact with the drag link and causes the pitman arm to move causing the steering wheel to bounce around. It is HECK A Scarry. Is it worth getting one of the "S" shaped draglinks or just go back to the factory Arm. THe only problem I see going back is the loss of travel due to the factory hight of the arm. OR should I try and get a new pitman Arm? Sorry for all of the BLA BLAing. IT is just that I'm Scared while driving on the freeway at 60-65 and hit a bump in the road and almost go off it. Any help would be SO GReatly appreciated. /forums/images/icons/smile.gif
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I would put it back to stock. When I had a 2.5" lift on my Jimmy I left it stock, and had no bump steer.
  3. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    stock steering arm should work fine
  4. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I've had a 2.5 inch lift on my truck for 4 years and it is just fine with the stock steering.
  5. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Hey ken I too have to say go to the stock arm and hold onto the raised one for the new lift,less you have to buy with the new kit.
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have 2.5" springs on the front..Left the stock set-up (ie.Pitman arm, Drag link) Been working fine for about 3 years now
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    For a 2.5" lift, I would go back to the stock steering arm and draglink and get the Skyjacker 1.5" drop pitman arm. /forums/images/icons/wink.gif
  8. UseYourBlinker
    Jun 7, 2000
    11,117
    Skyjacker 1.5" drop pitman arm How much do they cost?
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    About $75. /forums/images/icons/wink.gif
  10. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Just lift it higher/forums/images/icons/tongue.gif
  11. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Ideally what you want is the drag link as close to parallel as possible with the rear being very slghtly lower than the front. This is so that when you hit a bump and the front suspension is under slight compression the drag link is parallel and won't give you any bump steer. You would probably be ok with all the factory components and no dropped drag link with the 2.5" lift. Just my $.02
  12. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Scott & every one else. THANK YOU.
    It has been a PUCKER FACTOR OF 9 out of 10 while driving. I mean My sholders were tense (sp) just driving it. Not sure what was going to happen. I'm going to do it this week. NOW that it takes only 1.5 minutes with AIR tools LOL my previous post last week. I was having issues with droop on the drivers side but I would rather raise a tire while wheeling rather then Loose control on the freeway triing(SP) to drive it to my destination (SP)
    Again thak you ANd I will look into the drop pitman arm.
    You guys rock.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's what I did....lift it higher, only because I didn't happen to have a stock arm, and I had to cut mine up to remove it so I figured I'd never be able to get a stock one!
    I had a 2.5" lift with no correction, but the drop pitman arm seems like a great idea.
    That way you could step up to a 6" lift with your steering arm/pitman arm pair should you ever decide to go higher.
  14. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Either stock steering with the 2 1/2" lift or a Skyjacker dropped pitman arm.
