4.88 gears + 700r4 + 36 tires = ????
Discussion in 'The Garage' started by UseYourBlinker, Jun 19, 2003.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Hey fella's...and ladies. Haven't really been on in awhile just been a lurker. Anyone running 4.88's,700r4,and 36 tires with a 350 engine?? Any input would be great. Since I am gonna order the gears by next week. Also where did you guy's buy them from? It's for a 10 bolt/12 bolt combo. THanks!
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    This is the setup that Steve Fox was running for a while and it worked for him.
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    i have 4.56's with 35" BFG M/T's and i really think i should have gone with a 4.10. it'll pull and take off like a mug, but the highway RPM's kinda worry me. so i think 4.88's would be kinda hard on it, unless it's going to be a trail only rig.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Eric has the 700R4 with overdrive. I am running 700R4 with 4.56's and 35's and it is great at freeway speeds but I wish I had gone with 4.88's instead, it seems to want to search for overdrive when a slight hill is in sight.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    With a true 36 inch tall tire, the engine would spin about 2230 RPM at 70 MPH with 4.88's. For comparison, with 3.73's and 29 inch weenie factory tires, it would spin about 2120 RPM. 4.56's with your 36's would drop it back to 2085 RPM.
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i agree with 4x4H... I have 4.56s and 35s with a 7004r behind a mild 350. I wish I had gone 4.88s too... rpms are just a lil low while in OD at my normal interstate speed. RPMs could be a lil higher there, and a lil more low gear never hurt! Someday I'll prolly go to 4.88s for this reason... but its waaaay down the priority list right now...
    j
  7. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I have 4.88's and 35's. I can cruise all day at 70 too.
  8. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Got 36's and 4.56's. Wish I had 5.13's.
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Whad up Eric? HOLLA! /forums/images/graemlins/wink.gif
    I gots 3.73's/35's/th350... I will be going 4:56's in my 1 tons and 37's. /forums/images/graemlins/thumb.gif
    See you at blazerfest! /forums/images/graemlins/k5.gif
  10. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Ive got 4.56's and 36" TSL's and Im now looking for 5.13's.
  11. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Y'all know, just a couple of months ago 4.56 for 35's were the ticket, what happened?
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i'm glad i saved this on my HD for you goof's that refuse to search
    Zakk’s Dissertation on why 5.13’s are the best choice for a 700R
    Recently, I made the switch to 5.13’s in my D60/14B combo. I run a mildly build TH350 and 39.5” TSL’s. The 4.10’s I did have were killing everything: the motor, the trans, freeway “ get up” …all of it was terrible.
    So, after typing this up a few times, I will commit this document to the annals of time, and have a friend of mine host it.
    The problem with larger tires and a 700R and larger tires, is that you can’t seem to get enough RPM’s to get the OD to properly engage.
    Dr. Watson of ORD fame has this problem with the Art Carr 700R and his 42’s. There is just not enough RPM’s to shift in OD. So what little freeway driving he does do, is all done in Drive.
    When we mix this with tires in the 35-38” range, 5.13’s are a great choice.
    Assuming a true tire dimension of 35”, a vehicle with a small block motor mated to a 700R would spin 2241 RPM’s. Running with 4.88’s would have the engine humming along at 2132 RPM’s, only saving 109 revolutions of the motor per minute. All are calculated at 65 MPH.
    Assuming a true tire size of 37”, 5.13’s would net 2120 RPM’s at 65 MPH.
    Most small block motors are comfortable running between 1800 and 2800 RPM’s. 5.13’s with the addition of OD allow this number to be on the lower end of the spectrum, while allowing for maximum acceleration and off road performance. Gearing can make a motor that is slightly lighter on power really come alive, as I have found with my mild small block 350 with approximately 285HP at the flywheel.
    In closing, unless you bought your axles with 4.88’s already installed, there is no reason that this author sees to not go with 5.13’s from your present gear ratio.
    Let the flaming begin….
  13. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    depends on the rig and the use. I dunno, i never really noticed until a recent road trip, but 4.56s + 700r4 + mild 350 + 35s = rpms just too low for OD. That said, i dont have a tach... and Im not an engine guru or anything... but it seemed to me anyway that the gearing could have been just a lil lower.. and the rpms therefore just a lil higher. I think 4.88s would be juuuuust right for me. Others opinions/experiences can/will/do/should be different.
    j
  14. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    I run a small block with a 700r4, 44frt,12blt rear, 4.88 gears and 37" mtr's I like my setup works very well overdrive is nice to have
  15. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I've got a buddy with 10bolts, 4.88's, rebuilt 700r4, and 36x14.50 Radial Swampers. He loves the setup, hasnt broken anything, and he drives maniac-like. He did break some axleshafts in a pulloff contest (on pavement lol) but other than that he's been loving it
  16. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Got the 4.56/TH700/35" combo in my burb and it's not worth changing (I'll do motor mods first) but if you're buying, get at least a 4.88 and consider 5.13's. I have a hard time thinking you can spin a motor too fast in overdrive, especially when most of my driving is done at 3K+ RPMs due to the overdrive kicking down.
    There's room to err here with motor build specs, etc but that's my recommendation.
  17. UseYourBlinker
    Jun 7, 2000
    11,117
    Thanks for all the input! /forums/images/graemlins/thumb.gif
  18. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    I dont know if this is true but i heard after you go past 4:56 in the front with a 10bolt or 44 that the pinion starts to get very small and weak is there any truth to this??
  19. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    small yes, weak is a matter of opinion. I saw a D44 get beaten to snot with 5.13's and the R&P didn't go. Usually a u-jpint will go first on those little axles
  20. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Edit.......................
    So which one is correct, Randy's or 4lo.com??????????????????????????
    I am thinking that Randy's is more on since it has calculations for all trannys while 4lo seems to be calculated for a manual tranny...................
    Ah WTF cares anyway????? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
    Now I'm edumacated on why people are saying 4.88s.............
