4.88's and 10 bolt or 4.10's and d60 ?
Discussion in 'The Garage' started by BamBamblazer, Dec 5, 2005.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    Ok here is the situation. Right now i run 39.5 iroks, 10 bolt open front, 14 bolt spooled rear both with 4.88's. I have a front 60 in the garage with 4.10's as well as a set of 4.10's for the 14ff, and noooooo money to regear the 60 anytime soon. So the question is, would you just ron the current set-up or would you go ahead and swap in the 60 and regear the 14ff to match for now. 14ff pinion is still in a pinion support so regearing the 14ff would probobly take all of maybe an hour or so. No big deal. Give me your input on what you would do???
  2. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    i would do everything i wanted to the the 60 while its out and then put it in
    just run what u have the 60 isn't gonna give u any advantage as is
    if you break the 10b then you have the 60
  3. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    what he said, save up for 4.88's for the 60 and hope you don't break the 10 bolt in the mean time :D
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Save the 10 bolt with the same gears,and just sell the Dana 60. I will pay for shipping to California. Thanks in advance :bow:
  5. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    the 60 do I say any more :D
  6. RampageFSJ
    RampageFSJ 1/2 ton status
    Aug 18, 2005
    121
    Ulysses KS
    I`d say sell the 10 bolt and use the money on the Dana 60.
  7. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Is the 60 done? I mean, does it need anything to be ran under your truck? Like brakes, bearings, etc.
