4.88's or 5.13's??????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lv2whl, Dec 12, 2001.
  1. lv2whl
    lv2whl 1/2 ton status
    Mar 4, 2001
    130
    CA, USA
    4.88\'s or 5.13\'s??????
    I need your help. I have a '76 k5 with a mild 350, a th350, an np203, a Corporate 14 Bolt, and a Dana 44. I have some 42's i am about to put on. I dont know which gear ratio i should go with. What do you guys think? Thanks for your help. Sam
  2. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Re: 4.88\'s or 5.13\'s??????
    Well, I have 39.5s and 4.88s and they work out fine. I also have a healthy big block also. But, I would think you would be ok with 4.88s.
    I am thinking of doing 5.13, but only with the 44s.
    Ken H.
    '86 K5 up and coming
    14 bolt(Detroited),10 bolt,39.5 Boggers rear,
    TSLs front, 468 BBC, 350 trans, 205 transfer
    Rust free in Michigan!
  3. Re: 4.88\'s or 5.13\'s??????
    I have 4:88's with my 38's and a stock 350 TBI with flowmasters and I think it works out great. I had 44" Boggers for awhile and ran 4:56's and then 4:88's and I still think I should of had 5:13's. I think if you do highway driving I would go with the 4:88's. I couldn't imagine anything lower without Overdrive though. I run a 700R4 with my 38's and 4:88's daily back and forth to work and get 10 to 10.5 MPG in the burb. It gets 10.7 MPG on the freeway at 60 MPH.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>I Like my Burb'n on the ROCKS !!
    <font color=black>Imported to Kentucky through military channels !!
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    If you are a dedicated rock crawler, go with 5.13s. If you use it for any other kind of off-roading, go with 4.88s. Isn't 5.13 a bit tall for a D44? Seems to me the pinion would be quite small and, hence, highly vulnerable to breakage.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    4.88 would probably work well, I have 5.13's and overdrive isn't a real useful gear so I use 3rd a lot and for going down the road it could stand a little lower motor speed. If your idea of going down the road is 55-60, 5.13's would be OK.
    Why bother gearing the D44 to 5.13's? Just save the $ for a D60, you're going to need it if you wheel it very hard. If you don't wheel it hard you'll be OK.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
