4.88's too much for 35's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Jan 30, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    4.88\'s too much for 35\'s?
    I don't know what gear ratio to go to. I will be putting a 14 bolt under the rear with 35" Boggers and I'm not sure if 4.56 would be enough to get up and go. Would 4.88's be a wise decision or should I just stick with 4.56? Gas mileage isn't a problem right now for me, because I only drive to and from work and the lady friend drives me everywhere else.
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Re: 4.88\'s too much for 35\'s?
    Since you have an overdrive trans, I think that the 4.88's would work pretty good.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    You should be fine with 35's...
    According to Randy's Ring and Pinion, you will be running 2886 RPM @ 60mph in Drive and 1968RPM @60mph in OD....
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  4. CK5
    May 19, 1999
    21,624
    702
    CO
    I just regeared yesterday to 4:88 and with my 36" swamps they are fine, in fact I didn't notice as big of a differance as I thought I would going from my 4:10's.
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    4.88 with 35s and an O/D trans works great. Go as low as you dare.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  6. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    I'm running 4.88's with a 700r4 that doesn't lockup. Right now I'm running 35's until I find a set of 37's. I'm running 2300 rpm at 55 mph. It works great on the highway and I get a whopping 9.7 mpg.
    Steve Frisbie
    [image]http://albums.photopoint.com/j/View?u=1191682&a=8779286&p=28489343&Sequence=0&r[/image]
  7. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I have run 4:88s W/35s since last 7 yrs. Dana 60 with overdrive. 350TBI gets about 13 mpg. I have had 3:90 and 4.11s but I really like the 4:88s!
    SteveB
