4 barrel Carb on a inline 6 "292CI"
Discussion in 'The Garage' started by Looksback, Nov 13, 2002.
  1. Looksback
    Looksback 1/2 ton status
    Aug 12, 2002
    120
    Montana
    4 barrel Carb on a inline 6 \"292CI\"
    I have been tring to put a 4 barrel carb on my 292ci inline six, but the intake manifolds are vary expensive about $219.99 + S&H "From JC Whitney", but I do not have that kind of money would anybody out there have one thay might be tring to gett rid of?
    Thanks for the time
    LooksBack
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    Re: 4 barrel Carb on a inline 6 \"292CI\"
    i dont have one but i would like to see a pic when you do get it together.i dont think you could run A very big carb on a 6 cylander.what are you thinking of running?
  3. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    you mightwant to check clifford performance.they make a ton of I-6 perfprmance goodies.
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    If you want to get by cheap you can just run an adapter but then you have a limitation of the opening in the stock manifold. Does your motor have a 1 or 2 barrel to start with? The 2 bbl stock manifold would be a good upgrade from a 1 bbl and a 2 to 4 bbl adapter would be ok and still keep it cheap.
  5. Looksback
    Aug 12, 2002
    120
    Montana
    Well for one, the 292ci has a one barrel carb on it, but I was hopeing of putting a 4 barrel one it, but there is one thing I am worried about, that is trying to find a air cleaner that is not to large because the brake master cylinder would be in the way.
    But there is an intake manifold in the 1947-1954 Chevy-Duty catalog that 2 one barrel carb's can fit on. I can post a photo of my current set-up in about 2 hours. will put a lik on to look at.
  6. ds350
    ds350 1/2 ton status
    Jan 26, 2001
    190
    Bay Area
    2 barrel would be your best bet....Clifford has everything you will need. /forums/images/graemlins/thumb.gif
  7. Looksback
    Aug 12, 2002
    120
    Montana
    Well here is the link for the photos of the current set up I now have: http://www.geocities.com/looksback/Supply.html
    Dose -Clifford- Have a web Site?, I have seen a intake that uses two, one barrel carb's, I think that would be my best choice, because most air cleaners would be to large and my master brake cylinder would be in the way.
    LooksBack
  8. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    ive seen it done on ferds 300ci I-6, i hear that they make the horsepower and torque gains, personally if i had an ol' 4x4 truck with that setup, id go for it, id put that thing on there
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  9. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    http://www.cliffordperformance.com id say stick with a two barrel because a 292 wont use that much gas, it will just be overfeuled.
  10. Looksback
    Aug 12, 2002
    120
    Montana
    Also how would daul exaust work, the exaust manifolds can be bought, but that much loss of compression on a six?. but with a two 1 barrel carb's maybe a good idea?
    Looksback
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I put a Clifford 4V intake and headers on my '66 C10 w/250 c.i. along with a 600cfm Holley. The headers have 2-1/2" collectors and run into a dual-in/dual-out Borla. She's loud alright! I didn't have room to store my truck, and my buddy needed wheels.... so he's driving it /forums/images/graemlins/eek.gif
    The intake, headers, and carb cost me about $750 CDN
    The heated water jacket was essential. It would not run properly until it was plumbed in. The headers were shorties, and NOT for a manual transmission... I had to fab up a tight 90* to get past the bellcrank.
    I wanted a 390cfm 4V, but it would have cost me double what the 600 did, less common I guess. The 4V *should* be more streetable than a 2V, since you cruise with only two barrels open anyway, and half of 390 is a mere 180cfm. I couldn't find a universal Holley-type 2V carb under 500cfm. This Clifford intake can be had with two different top plates - a Holley 4V (which I got) or a Holley 2V.
    I'm using an air cleaner off an 87-93 4.3L TBI S-10 pickup.
    There's a more complete write-up on a 292 4V at Truckworld:
    http://www.truckworld.com/How-To-Tech/Chevrolet-Engine/Chevy-engine.html
  12. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    If power is what you're looking for, why not find a working used 350 and swap it in there?
  13. Looksback
    Aug 12, 2002
    120
    Montana
    Good idea, I will have to keep an eye out for some air cleaners from an S-10 "4.3L do thay have 3 cylinders on each side?" The reason I do not just go with a V8 265, 283, 305, & 350. well not sure, I would rather keep the truck sort of orginal and stay with the 292. Another thing I like the MPG, but would like a few more horses under the hood.
    LooksBack
  14. u2slow
    May 9, 2001
    2,217
    BC Canada
    The reason I stuck with the "six" was the neat factor. The 350 would be hard on the SM420 (rated for 281 lb-ft). I didn't have V8 frame brackets, and driveshaft needed to be lengthened.
    Nice room under the hood with the six too!
  15. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    Don't mean to side track this thread but since you guys are talking about 292 stuff... Does anyone know of a source for the engine crossmember and motor mount brackets for a 292? These would have to be out of a 73-86 4wd. I have looked around the local salvage yards with no luck and GM has discontinued them.
    U2Slow if you want to swap I've got a crossmember with brackets for a V8 out of an 84 K30... /forums/images/graemlins/grin.gif
  16. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    How soon do you need them? I have a line on a 77 K30 w/a 292. Trying to talk the owner out of it. /forums/images/graemlins/grin.gif
  17. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    No rush on needing the stuff, it's for a project that I'm collecting parts for (right now it's a bare frame). I've got most of the drivetrain but I still need to find a body before I start.
    If you get it, let me know what you want for the crossmember/brackets because I'll definitely need them.
    Thanks! /forums/images/graemlins/thumb.gif
  18. Looksback
    Aug 12, 2002
    120
    Montana
    Also I was woundering how would a two speed rear end work with a 292ci, and are thay easy to find? my normal gears are 4.56:1 "I think".
    Looksback
  19. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A buddy of mine rebuilt a 258 Jeep I-6 a few years ago and gave it the whole Clifford treatment. Intake, headers, cam, and a Holley 390 CFM 4 barrel carb. He was VERY happy with the results!!!! /forums/images/graemlins/thumb.gif
  20. u2slow
    May 9, 2001
    2,217
    BC Canada
    Do you know for sure if a 292 4x4 was ever offered? /forums/images/graemlins/confused.gif I've only seen them with a 250 c.i. Not trying to rain on anyones parade... it could be just a like a 454 K-Suburban - sounds sensible, but never offered.
    I'm dredging through my memory here... but aren't the 250c.i. mounts the same as V8 mounts on a 73-up 4x4? Now if it is, the only difference between the 250 and 292 is the passenger side mount sits further back, correct? Couldn't you just drill/cut the rivets and mount the frame bracket where it needs to be? At least the engine-side of the bracket, and the rubber mount itself, interchange from 2wd to 4wd.
    Thanks, but I've got lots of that stuff. I'm parts rich and time poor! /forums/images/graemlins/rolleyes.gif
