4 Bolt Main 400 Chevy Engine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LA Bogger, Feb 24, 2002.
  1. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    Is there a strength difference between 400 small block 2 bolt main and 4 bolt main? I hear that the 2 bolt is actually stronger than the 4 bolt. Any information would be appreciated.
    Eat More Mud!!!
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    If your looking to build your 400 for 0-5500 rpm then either one will work great. If your looking for something to run up in the 5500 to 7000 range (yikes) or a forged crank then it would be worth your while to get a 2 bolt main and adapt it to 4 bolt with a splayed 4 bolt kit. You can go with a stock 4 bolt block and probably never have any problem as well. The strength issue your refering to is where the 4 bolts crack between the bolts which is why many people prefer the splayed kit. Hope this helps.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://community.webshots.com/user/borregok5> Pictures</a>
