4 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, Jun 30, 2000.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    how do I tell if my block is a 4 bolt main
    [​IMG]Go prepared
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I think you have to pull the oil pan and just count 'em. It might also say what it is on the casting number.
    YEEEEE HAWWWWW[​IMG]
  3. James90
    May 18, 2000
    986
    Rocky Mount NC
    is there a code or some thing
    [​IMG]Go prepared
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    you could look on the back of the block( drivers side ), and find the casting number. the number is directly behind the head on the block, slanted a little. You'll need to climb on there with a flashlight and a rag, wipe it down, check your number, then run the number. or you can drop the pan and count the main cap bolts. Having a 4- bolt block is very good, But remember, you don't really need it unless your making serious HP or torque, like over 350. JS
  5. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    i think if it is the original motor then it would be a 4 bolt. somebody correct if i am wrong, but i think i read somewhere that all trucks had 4 bolts mains caps.
    Knife.
