4 Core Radiator Conversion help...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by waxer@work, Aug 26, 2000.
  1. waxer@work
    waxer@work Registered Member
    Aug 3, 2000
    32
    I currently have a 2 core radiator in my 74 K5 w/350. I have overheating problems and I heard about the 4 core radiator upgrade. I recently purchased the Big 4 Core Radiator that is made for the 454 engine. I have heard how some of you had to upgrade the upper Radiator support. Does anyone have the part # for that upper support? Or if now part number, does anyone know which vehicle I need to tell the dealer I have to get the right support? Thanks in advance.
  2. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    If it's a stock replacement radiator it should bolt into place. You just move the upper brackets to the outer set of holes already in the core support. That was all I had to do on my 1985.
    Steve Frisbie
  3. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    The only thing that I had to change was the brackets that hold the top of the radiator in place. I took them out of a truck that had a four cour in the first place. The four cor is wider than the stock one
