4 core radiator mount for 83k5
Discussion in 'Parts & Trucks Wanted' started by down4thakrown, Jul 27, 2004.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    what it says
    top part
    if u got one shoot me a pm /forums/images/graemlins/thumb.gif
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I have one from a 78 not sure if it will work or not I can send ya a pic? /forums/images/graemlins/dunno.gif
  3. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i dont think it will
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    They are like $15.00 at the dealer. /forums/images/graemlins/thumb.gif
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    you know the part #??
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
  7. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I saved this from a post a few months back.
    "I did my 91 K5 awhile back. I got a 4 core radiator from AutoZone, part# 433730. From the dealer I got four new rubber mounting pads, part# 6264100, the upper panel (bracket), part #14018600, and the shroud, part# 14021289. Everything bolted right up."
  8. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/waytogo.gif just copied those numbers into my parts book! /forums/images/graemlins/peace.gif
  9. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I found another one that Russ posted:
    "Here are the numbers I used to purchase the parts from the chevy dealer:
    #14018600, Panel Assembly, 1 each @ $14.27
    #6264100, Pad, 4 each @ $4.10
    The panel is the one that covers the top of the radiator for a 4 core. The four rubber pads are two for the top and two for the bottom to hold the radiator in place. I have used those parts to install a 4 core in my 90 Blazer and also in my 88 Dually, and they are a perfect fit."
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have a pair of 81 up 4 core mounting brackets
    73-80 used a large flat panel full width(for =taller radiator anyways, but shorter oens for some of the 350's and the 6's used right angle panel mounted to front face of rad support down lower than usual, i just saw one at scrap metal yard today along with hood hinges and trans linkage setup and exhaust pipes and such all for 73-80 sbc trucks
    67-72 used pair of van style brackets
    you guys dont really know gm trucks too well ?
    or ?
    good luck
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I just pulled one of those off an 86 pickup that was bone stock /forums/images/graemlins/deal.gif
    Last time we where up there you said you didn't have those brackets /forums/images/graemlins/dunno.gif /forums/images/graemlins/tongue.gif
  12. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Randy,
    My GM 1990 RV Parts and Ilustration Catalog shows part #'s
    14018600, Panel, upper radiator mount for 1985-88 7.4L
    14039948, Panel, upper radiator mount for 1985-89 7.4L, 6.2
    14022775, Panel, upper radiator mount for 1985-89 292
    GM obviously used those panels all the way through 89 at least. I have put one on both my 88 model and 90 model with the Autozone 4 core radiator and they bolt right on.
    Russ
