4 Core radiator Mounts
Discussion in 'The Garage' started by kick, Nov 9, 2004.
  1. kick
    kick 1/2 ton status
    Dec 19, 2002
    385
    FL
    I have a 1990 Blazer that currently has a 3 core radiator. I know I need to change the mounts and rubber cushions. My question is will the bolt holes in 4 core mount brackets line up with the 3 core brackets or will I have to drill to make it work. /forums/images/graemlins/thinking.gif
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Unless the 90 is different than earlier years, the passenger side mount will use the same holes and the drivers side will use another set of holes about 6 inches towards the fender. No drilling required, just the new mouunts and cushions.
  3. Grim-Reaper
    7,385
    Atlanta
    4 core and 3 core use the same mounts unless the 4 core was from a Deisel application. The diesels got a wider radiator that used the second set of holes.
  4. BlueBlazer
    Feb 15, 2001
    1,940
    Yep, I forgot the gas 4 core was narrower, either way it sounds bolt in for him /forums/images/graemlins/thumb.gif
