4 core radiator problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88k5blazin, Mar 17, 2007.
  1. 88k5blazin
    88k5blazin 1/2 ton status
    Nov 27, 2006
    484
    clark new jersey
    got a four core radiator for an 88 k5 and went to bolt it in and the passenger side mount did not line up with the stock bolt holes. anyone know if any fab work is required or am i over lookin something. thanks in advance
  2. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Post up a pic and someone here can help. Fab work should not be required. You must remember, all new aftermarket radiators are made in either Mexico or China now, so God only knows what you got if you went that way.
    Jimbo
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Mine pretty much slid right in, I'll have to go see if I did anything special to it.
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    My 4 row into an '85 Burb didn't fit accross the top. I used zip-ties. The fan shroud needed fudge too.
  5. oh-zj-io
    oh-zj-io Registered Member
    Sep 29, 2006
    40
    Central Ohio
    I just did this and I had to slightly cut the 'opening', on the passenger side, of the top bar that holds the radiator to get mine to line up. Once I did that it slipped on and lined up fine. Like was posted before, the aftermarket radiators will probably NOT be direct bolt in fits. Expect a little messing around. The main thing is, if you get it solidly installed and the shroud fits, you're gold.
    Al
