4" for 87, cant sell it need advise on good lift
Discussion in 'The Garage' started by purple76pearl, Jan 19, 2003.
  1. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    4\" for 87, cant sell it need advise on good lift
    ok on the 76 i have a superlift, its not bad i guess i like it kinda stiff, but for my 87 since i cant sell it if i want to put a 4 inch lift and some 33/14.50/15 what is the best lift for everyday driving so i can tear in to the blazer and get it set up right, all opinions welcome please help
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
  2. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    Re: 4\" for 87, cant sell it need advise on good lift
    #1 should be BDS!!!! /forums/images/graemlins/thumb.gif
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Dont even consider Rancho. Worst mistake ever /forums/images/graemlins/1zhelp.gif
  4. purple76pearl
    Jan 13, 2003
    450
    missouri
    whats bds? /forums/images/graemlins/k5.gif
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Big Dick's Suspension. From everything I'm hearing, the springs are really good with a soft spring rate.
    That should be the the thing you look for when deciding on a set of springs is the spring rate. There are a lot of factors that affect the spring rate, but a good general rule of thumb at looking for a set of springs is the thickness of the springs. A thicker leave setup will yield a higher spring rate resulting in a stiffer ride; whereas a set of leaves that are many, yet real thin, plus has a taper at the end will have a soft spring rate resulting in a better ride.
  6. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I can't speak for the others, but I would stay away from Rough Country. I have it and like it. But, a Rough Country 4" lift will actually come in closer to 5". If you are only going to run 33's, I think you will feel odd. While it is the most complete kit you can get for the money, I think it would be a bit much for your application.
