4-hi & 2nd vs. 4-lo & 3rd
Discussion in 'The Garage' started by mountainexplorer, Oct 10, 2004.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    For those of you with the SM465 and NP205 combo, how would you compare the overal gearing that 4 high and 2nd gear gives you and 4 low and 3rd gear?
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    To the best of my memory third gear is about 1.6 ( or close to it ) and second gear is 3.58 ( IIRC ) so that would make taking off in third and low possible to get more wheel speed if the motor is happy with that gear .
    Tom
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    All the previous times I've driven/played with a manual tranny, I've always felt 4-lo/3rd was the best range for most types of off roading. I always liked leaving the t-case is low range because if you needed to go lower, you just downshifted. Also gave the best powerband for the RPM's, too. That picture of my old Brown Turd in my avatar, I was playing in that mud hole in 4-lo/3rd all day long. /forums/images/graemlins/waytogo.gif
  4. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    As an avitar it looks like a sand sculpture. /forums/images/graemlins/laugh.gif
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    4hi 2nd = 1 x 3.58 = 3.58
    4lo 3rd = 1.96 x 1.7 = 6.086
    so a hair lower then 4hi 1st but with closer gear spacing to gears above and below meaning easier to shift if you need to.
    odd comparison question.
    4lo 2nd is the most common gear for me
  6. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    iirc 1.96 x 1.7= 3.32
  7. mountainexplorer
    Nov 14, 2001
    4,903
    This is mainly for mud bogs/races where you have a 150' pit. I've always done 4-high and 2nd gear (2nd referring to the 2nd forward gear- the next gear after low gear- listed on the shifter knob as 1). By 3rd I mean what is listed on the knob as 2, but is the 3rd forward gear in the tranny.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    sorry must have had something already in the 'calc'
  9. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    4lo and 'third' should give you a hair more wheel speed for the rpm. Not really sure if there is enough difference between 3.58 and 3.32 to notice though.
    Rene
