4 inch lift and drive shaft ?'s...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben Malinski, Jan 21, 2002.
  1. Ben Malinski
    Ben Malinski Guest
    4 inch lift and drive shaft ?\'s...
    I'm in South Korea and just can't run on down to the local parts house if I start this project, so... if I install a 4 inch suspension lift kit, does the drive shaft need to be extended? Brake lines replaced? Steering arm? Anything else I left out.....the same question's if I go with a 6 inch lift. Any advice, comments or suggestions welcome! Anyone stationed in Korea? I split my time between Camp Humphries and Youngsan, I have that Maroon/Silver full size 84 blazer with the wild horses painting on the side windows.
    I don't know the secret to success but the key to failure is trying to please everyone!
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Re: 4 inch lift and drive shaft ?\'s...
    If you go with the 4in.. You don't need to extend the drivelines.. You do want to get a steering arm and drop the t-case and extend the brake lines.. If you went with the 6in. You will need to do all of the above and extend the brakes lines...Hope this helps...Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
