4 inch lift, front driveshaft issues
Discussion in 'The Garage' started by Janitorjim8, Aug 7, 2005.
  1. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    so i just finished installing my Pro Comp 4 inch lift kit. to even get the front axle perches to align with the leaf springs i had to disconnect the driveshaft. now it seems like this one won't be long enough. is there a simple solution like a shim between the transfer case and driveshaft or am i gonna have to get this one lengthened. if there is a shim where can i get it at? any help would be greatly valued.
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    just get it lengthened. im unaware of any kind of spacer.
    how much spline are you showing with the shaft installed?
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    If you have a 80's K5, they sell a 1" spacer that goes between the t-case flange and the flange on the driveshaft.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Whats funny is some of us have no issues , and some of us do .
    I hit my exhaust a little flexing ( small shop exhuast ) , but run the same shaft as stock .
  5. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    hey 85mudblazin, do you know where i can get one of these?
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    But there is no way your front DS is to short with only a 4" lift. :crazy:
  8. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    Its really funny...ive heard of the same sorta issues...4-5" showing spline, but my front shaft is fine with 7" of lift...no splines show at ride heigth. The only issue i had was it hitting my y-pipe...cut it, installed the shaft, drove to the shop and had them cut more and bend a new pipe and weld it in for under 100$. Its wierd how things happen like they do.
