4 Inch Lift Question: help please
Discussion in 'The Garage' started by Vetteman61, Jan 22, 2007.
  1. Vetteman61
    Vetteman61 Registered Member
    Jan 11, 2007
    93
    Kentucky
    I just bought a 4 inch lift from a friend for my 87 K5. He said he didn't have to extend his rear drive shaft, but mine seems to be sticking too far out of the tranny. Further than I feel comfortable with. Has anyone else needed to extend their rear drive shaft for a 4 Inch lift?
    Will the front drive shaft need to be extended as well with the 4 Inch lift. As of yet mine is frozen and I have yet to pull it all the way off the truck to try to free it.
    Does anyone have suggestions on removing the stock steering arm, mine seems to be extremely stuck?
    Thanks,
    Brandon
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Each ride is different but with my 4" I did not change any of my driveshafts. I have a 60 and 14FF though so that my be part of it. The slip is about 8" long so you can have quite a bit out of the tcase and be fine.
    Post up some pics and let us see what you got.
    Ira
  3. Vetteman61
    Jan 11, 2007
    93
    Kentucky
    blazer
    Thanks, I should be back over to the shop in a week or so and i'll take the camera.
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I agree, all trucks react a little differant to the same setups. But when I had a 4" system on mine I used the factory shafts. All I needed to do was drop the transfer case a little to help with the rear pinion angle.
  5. BIGNICK91
    BIGNICK91 1/2 ton status
    Jul 10, 2006
    384
    ARVADA, CO
    I have not changed mine either
  6. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    For the Pitman there are pullers, but try using a large screwdriver in the open slot that the bolt clamps, and spread the two "ears".
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Beat on the arm until you, or it, cries.
  8. Never Satisfied
    Never Satisfied 1/2 ton status
    Aug 21, 2005
    709
    Lafayette, Indiana
    I did have my driveshaft's lengthened with my 4" ProComp lift. They were both borderline and I felt like they needed to be lengthened.
  9. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    I hAd to have my front shaft lengthened, but my rear was fine.
  10. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    my drive lines are fine with my 4 inch rough country lift
  11. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Mine are fine (I think) with my 4" lift. If I go 6", will it require lengthened driveshafts? How much do you think it would cost to get them lengthened at a shop? Thinking about going with a 6" lift sometime soon.
  12. Vetteman61
    Jan 11, 2007
    93
    Kentucky
    dropping transfer case?
    I know absolutely nothing about dropping the transfer case. What all is involved in this or how do you do it? What would I have buy to do this? Does it lower the whole thing or does it just reposition it to point at the pinion better?
    Thanks,
    Brandon
