4 inch lift question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Norm, Mar 8, 2000.
  1. Norm
    Norm Registered Member
    Mar 6, 2000
    7
    I have just installed a Rancho 4 inch lift on my 83 project Blazer. I used 4 inch springs in the front, and 4 inch blocks in the rear. The problem is the front is now 2 inches higher than the rear. From axle center to bottom of front fenders is 27 inches and axle center to bottom of the rear fender is 25 inches. Can someone else with a 4 or 6 inch lift sanity check me on this. I either need to put in an add-a-leaf or replace the rear springs, but in order to order new springs I need to make sure of the size. On another note, any recomendations on a body lift brand?
  2. 77K-5
    77K-5 Registered Member
    18
    Texas
    Well luckily somebody told me about this problem before I installed my 4" lift on my '77. What I did is ordered 4" supderlift springs and 5.5" procomp blocks for the back.
    The reason for your prob is actually not a problem - the springs will take a while (6months or so) to release some of the flex. Right now with new springs it is more than what it is supposed to be cause they are new - they will wear down in a bit. Solution - get 5.5"block or new leafs in the back (matching)the front lift size.
    Good luck,
    BS
  3. Todd78/87
    Todd78/87 1/2 ton status
    Feb 18, 2000
    436
    Haines, Ak
    When I ordered my Tuff Contry 3" lift,, the guy one the phone said he would send me 4" rear springs.
    Todd 78/87[​IMG]
  4. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    If you are going by the front end actually being higher when you look at it, the rear on all K-5's sag some. If you are going by measurments alone, take a look at the top body line and measure from it. The front wheel openings are higher up on the body than the rear. I cut out both of mine to the same height.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
  5. Crash90K5
    Crash90K5 Registered Member
    84
    Santa Clara, CA.
    Call me crazy, but my wheel wells look different when looking at one side. The front well comes up much higher than the rear. But you're right about Blazers sagging. Most lifts are designed with the Chevy truck in mind, and they don't have as much weight in the back. I solved mine by putting a 2" add-a-leaf. A lot of people will tell you don't do it, and on a truck I would agree. But on the back of a Blazer, with the added weight, it has worked well for me. It's a couple of years old, so it has weakened a little, but IMO it didn't ride that bad to begin with.
    [​IMG] <font color=blue>Crash90K5</font color=blue> [​IMG]
  6. fredd
    fredd 1/2 ton status
    127
    Madison, Alabama, US
    That's the way is usual is.
    On my '88 Jimmy, I put Skyjacker 2 1/2" up front and 4" on the rear.
    My '88 K5 has Skyjacker 4" up front and 6" on the rear.
    Both are level with these spring sets.
    fredd
  7. Matt N.
    Matt N. Registered Member
    24
    Seattle WA
    I don't think it is 'sag' per se, but just the way the spring hangers in the vehicle were designed from the factory...after all, why would brand new springs be 2 in shorter in the rear? I would speculate it's probably to keep the tailgate managable for shorter people. Having 2 inches greater lift in the rear than the front is the way most people have attacked the issue...
  8. I put a set of 3/4 ton rear springs on my 77 K-5 to level it with the Superlift 4" kit I had on it !!!
    <font color=red>BigBurb<font color=red>[​IMG][​IMG]
  9. wnderbra
    wnderbra Registered Member
    Feb 18, 2000
    47
    Virginia
    My 83 has the same 4in rancho lift with blocks in the rear.They have been on there for a long time and the rear is still 2in lower so I dont think the new springs will relax to the proper height.Try launching the truck big the landing may drop the front to match the rear naaah just buy more stuff what's money when you love your ride
  10. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    easy answer...new springs, 4" taller than stock! stock is wore out old,sagging, best answer is new rear springs from rancho or add a leaf. Blazers shouldn't sag...they didnt from the factory. good luck
    IT'S A BLAZIN PAST THAT JEEP THING...YOU WOULDN'T UNDERSTAND
