4 inch lift shocks?
Discussion in 'The Garage' started by jjlaughner, Jul 21, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'm wondering what size 4" lift shocks are in relation to the photo?
    A-body length
    B-shaft length
    C-overall length
    d-installed overall resting length
    Thanks! /forums/images/graemlins/thumb.gif
  2. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Re: Question about shocks for a 4\" lift - measurements needed
    NO ONE has 4" lift shocks? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
    If anyone has them all I really need is the body length and the overall installed ride length (A&D).
    /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gifThanks, come on! /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I will measure mine tomorrow if nobody gets here first. Front or rear?
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I can get the ride length and the body length off the front ones on my truck, but the rears have a custom mount so the ride hieght wont do you any good. I should have them posted here in a couple of hours when I get to Decatur.
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Both if possible. I'm probley going to change to a f-250 front shock tower but I'm get getting ideas.
    Rears are what I'm most curious about though! /forums/images/graemlins/thumb.gif
    Even if some else does get here first post up too!
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Good deal! What are the custom mounts /forums/images/graemlins/thinking.gif Thats what I'm thinking up for the rears, something custom.
    I'm going with a 3" TC-EZ spring in the front and rear, probley need a zerorate up front, then I'll push the front axle up an inch for wheel well clearence, this is the DD so no fender trimming! /forums/images/graemlins/deal.gif
    Well maybe a SMALL bit of the corners if needed /forums/images/graemlins/thumb.gif/forums/images/graemlins/rotfl.gif
  7. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    if you're going to custom mount em, just get the longest shocks you can get and mount accordingly. Thats what I did with the DT8000s... just got the longest ones they make and then used F250 towers + a 55willys x-member to mount em. works well.
    j
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    True, I'm just curious if the shocks for the rear will work at the stock location till I get some things figured out. I'll most likely do an axle swap and the new springs at the same time. SO, I'm trying to figure out mounting areas and get some ideas before hand.
    I'm actually going with a 3" spring and hoping I can use the gabrials in this pic , so I'm trying to figure out what the stock 4" lift shock sizes are and their ride heigth /forums/images/graemlins/grin.gif
    Anyone use a f-250 shock tower in the rear without a body lift? (I have a 1" body lift)
    Since its a daily driver I will probley still go one front one rear like stock but move the mounting point on the frame if I need too /forums/images/graemlins/thinking.gif
    I know it will be easier to weld up brackets on the new axle before it goes in though /forums/images/graemlins/wink.gif
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    NO BODY HAS 4" LIFT SHOCKS /forums/images/graemlins/smirk.gif
  10. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    OK sorry dude I forgor I was supposed to do this. These are approximate but close /forums/images/graemlins/thumb.gif
    A. 14-15"
    B. 13-14"
    C. 27-28"
    D. Front rest at 21"
    E. Rear rest is at 22"
    These are Superlift shocks that came with my 4" kit.
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Sweet thanks /forums/images/graemlins/thumb.gif
