4 inch lift ?
Discussion in 'The Garage' started by BURBANDUX, May 6, 2005.
  1. BURBANDUX
    BURBANDUX Newbie
    Apr 23, 2005
    3
    WACO TEXAS
    Need your advice on this issue: :confused: Ive got a 85 Chevy 4x4 Suburban. I have just intalled a 3 inch body lift..Now I am wanting to go with a 4 inch suspension lift. What is the best way to go about this ? Stay wtih stock springs and do a shackel flip ? or buy springs ?
    This is my 1st attempt at this and any advice would be greatly appriciated.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    if you have saggy butt problem get a 1-2" block also or springs or add a leaf. this will help level it out in the back.
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    search the forums.... this is the most asked question of all time on ck5.
    short answer: 4" lift springs in front, shackle flip in back... new longer shocks, brakelines etc. Yes, you may have to lengthen your driveshaft and/or run shims.
    j
  5. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Run springs in the rear if you tow. If you never tow things then a shackle flip is the way to go.
    Now, I know some people tw with the shackle flip and have never had a problem, but I don't think I want to take the chance of something bad happening. General concensious is Do Not Tow With A Shackle Flip, so I'm sticking to that.
  6. BURBANDUX
    BURBANDUX Newbie
    Apr 23, 2005
    3
    WACO TEXAS
    Thanks for the advice, since we will b using it for Duck Hunting and will be towing a small trailer, I will go with the new springs. Thanks again
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    NO, you do not have to get a longer driveshaft, if you run lifted springs on the rear, then shim it, if you run blocks, make sure they are the tapered ones.
    Been runnin blocks for a few years now, and wheel the crap out of it with as serious flex as the rear shocks will allow,(they are longer than stock, but still limit travel) and i have NEVER had an issue with my driveshaft, or any vibrations from the different angle. The longer driveshaft on the Burbs are not as picky as the Blazers are with U-joints.
    Runnin a shackle flip, you probably won't need shims, as the angle of your springs hangin on the flip kit will change.
