4 inch lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tybee, Aug 26, 2001.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    How hard is it to get the U-bolts off, do I need a really large impact wrench? Also with a 4 inch lift do I need to extend my brake lines?
    1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31x10.50 x 15
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    A braker bar should get the u-bolts loose. With a 4inch I would reccomend getting some new brake lines. Most 4 inch kits come with brackets so you don't need new lines but if you want to flex it you should get them.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    for the u bolts just spray some pb blaste ron it and uwill be fine.
    extended brake lines are needed if ur gonna wheel, but just street riding u dont.
    <a target="_blank" href=http://confederate9.coloradok5.com/>confederate9.coloradok5.com/</a>
    <font color=red>K5: Because size DOES matter</font color=red>
  4. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Thanks for the replys.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Cut the u bolts off. It'll take you forever with a ratchet. An impact wrench would probably be totally useless (always has when I've done it). Usually you destroy them (flatten threads) when you remove them anyway. For the safety factor, I'd replace them.
    Tim
  6. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Whats the easiest way to cut them, sawzall or grinder?
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Grinder!!!!
    If it ain't broke.......Don't fix it....
  8. Grim-Reaper
    7,385
    Atlanta
    Grinder with a cut off wheel. Pops them off in about 1 minute if you get a good wheel. Watch yourself when it comes loose and have a jack under the axle.
    When you put the new ones on you need to set the axle on jack stands to get the weight on the springs. Check them after about 100 miles. They will strech a little and need to be retorqed.
    The EZrides are the ticket for best ride and flex. I hate my Rancho's and about to swap them out after seeing a few trucks with the EZ's. communities.msn.com/OffroadK5s
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
