4 inch lift ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Oct 31, 2001.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i was under my truck today in my auto class and i noticed that the pipes that come down from my exhaust manifold go across my t-case and i f i were to lift it 4 inches my drive looks like it will be hitting my piping. even if i drop the t-case it looks like the front drive shaft will still rub on my piping. any sugestions, well i could get some headers and just run them open all winter
    high
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Thats common. On my Jimmy it rubs only when the axle is articulating or when its on a rack at work. Now for the burb on a good bump it rubs, thats how close that one is. I dont know if lifts change it or not, or if dropping the t-case will make a difference. I dropped the t-case on the Jimmy with the factory spacers, and the lift is the tuff country ez ride. The burb I did not drop the t-case, and its a rancho lift.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. CarolinaBogger
    CarolinaBogger Registered Member
    Apr 17, 2000
    86
    Boone, NC
    When I had my 4" on my 89 Blazer, I never had problems with the front shaft touching the crossover pipe, even though it was pretty close. I had the front end articulated and it still didn't touch (to the best of my knowledge). And I do have the t-case dropped. I just put a 8" on and I'm gonna have to cut, drop and weld the pipe back together. You should be alright, but then again, not all Blazers are exactly the same. If it does rub, it probably won't cost alot to have the pipe dropped.
    CB
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Never had a lift and single exhaust on the same truck, so I guess I wouldn't know.
    Tim
  5. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I had this same problem so I had my local exhaust shop cut the old one off and put a new one in closer to the t-case and above the skidplate. It only cost about 65. Not too bad.
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  6. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Get that exhaust on top of the drive shaft. Your local muffler shop should know how to do it. My drive shaft was impacting mine and I figured it would get torn off sometime being below anyways.
