4 inch lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85 4x4 shortbed, Apr 8, 2003.
  1. 85 4x4 shortbed
    85 4x4 shortbed Registered Member
    Apr 7, 2003
    20
    if i swap 3/4 ton axles onto my 1/2 ton shortbox with a 4 inch lift would a 35x12.5 rub?
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    everyone will tell ya diff. Basically it comes down to the fact they PROBABLY wont on the street, but the first bump you take while turning, they will eat the fender.
    also, please fill out your profile, someone might be right around the corner
  3. blaz90in
    blaz90in Registered Member
    Jan 9, 2003
    58
    Michigan
    Not to steal the thread,(im on my buddies sn and he is out of town for a long time)ill be ordering a 4 inch superlift wiht springs all around..ill also get a ord 1 inch body lift to try to keep the 35x12.50x15 bfg mud tires out of the fenders....would this work are will i have to chop some of the fenders...
    Eric /forums/images/graemlins/k5.gif
  4. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    start cutting !!! if not it will rub
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    that should work, im gonna hafta do a 2" but my tires are 14.5 wide, so it should work, you could always extended the front shackles 2" to give a 1" lift in the front if you need it.
  6. Biguub91
    Biguub91 Registered Member
    Nov 25, 2002
    33
    Texas
    I have a 6" lift with quick disconnect and the first weekend out my front tires ate my fenders. I dont know how much trimming is needed for a 4" but light to moderate is needed for a 6". I have 35/12.5 MTR's
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    yeh thats true, i run my swaybar.
  8. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    as do i, i was about to rip it out because i couldnt get a bolt back in, but i managed to, took a hour and a half and 3 guys and i was gunna melt the bushing out of the sway bar end, but we got it in, 35X10.50's might get you by, but they might look awful goofy going down the road, of corse that is what i might buy, so i guess you gotta do what you gotta do to get it on. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.giflifted /forums/images/graemlins/truck.gif
