4 inch lift
Discussion in 'The Garage' started by kerwinq, Mar 9, 2004.
  1. kerwinq
    kerwinq Registered Member
    Jan 25, 2004
    20
    Boise, Id
    I am looking at the 4 inch lift kit from Rough Country. The price seems pretty good. Is anyone using the shocks that come with the kit and how good are they? I can get the kit for 80 less without the shocks but what would be a good choice if I did this.
    Thanks for the help, Kerwin
    75 Chevy 1/2 ton Shortbed 4X4
    85 1/2 ton Stepside Lowered 3/4
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I am using the Gabriels from Autozone in the rear, their a little longer, and I put my kit shocks for the rear up front. Someone I know with a rough country lift called them and got different shocks, but he has 2 up front each side. Are you going to use the lift blocks or something else. A shackle flip would ride better and no worries about block or longer u-bolts breaking or popping out. /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
  3. kerwinq
    Jan 25, 2004
    20
    Boise, Id
    I was going to go with blocks in the rear but if the flip gives a better ride I will have to look at that more. Is there a company that has just the flip kit?
    Thanks, Kerwin
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    4" block or shackle flip, it rides the same, still using the same spring. If your rear spring is wore out like mine is, just buy new springs all around. I am using a block and am having no problems with it. The shocks they originally sent me were not stiff enough for my problem of a sway from side to side while driving, so they sent me some nitrogen gas charged shocks which are rougher and did help out alot with the sway, but i still have it, i need new springs. The shocks that came with the kit are fine,and you should be ok with themm but i personally just needed some tighter ones for my particular problem.
  5. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    I have the 4" Rough Country lift with springs in front AND rear. I would not reccomend the Rough Country line wether you use blocks or springs or whatever else. The Springs are stiff as hell!!! /forums/images/graemlins/yikes.gif. Even if you do a shackle flip, you will have the springs up front and that is where I notice the biggest problem. The front end bounces hard on dips in the road and continues to do so for a mile down the road /forums/images/graemlins/dunno.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/ooo.gif. Off Road, the springs react to every little bump as if it were a 2 foot boulder at high speeds.
    If you look, there is a chart with the spring rates of many companies in here somewhere, and RC is second to highest! NOT GOOD!
    Anyway, not to burst your bubble, just sharing my own experience /forums/images/graemlins/dunno.gif. There are several other brands comparibly priced that are MUCH better ON and OFF ROAD! /forums/images/graemlins/peace.gif
  6. kerwinq
    Jan 25, 2004
    20
    Boise, Id
    Which kits are priced close to the Rough Country? When I talked to a Rep they said they were deluxe(?)ride springs.
  7. 4xcrazy
    Oct 31, 2003
    9,472
    5
    I had this same hard ride problem when i had one of the shocks from the kit, and one Autozone shock ( i have dual shocks up front) it was as hard as a Mack truck, then took off the Autozone shock, and the ride smoothed out ALOT, but then had my sway problem, so as i mentioned, i replaced them with those Nitrogen gas shocks and it is a firm ride, but not hard, but the rear is still soggy as i also mentioned, the original wore out springs. BTW i have the EZ ride springs up front.
  8. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    I went to e-bay and got 4in. rough country kit, $350. to my door, had everything I needed, I did not use the shocks as I had already bought rancho 5000's the year before (when trying to come up with enough parts to build a kit). Compared my backward banana springs these are great. yea they probly ride a little stiff, but work great holding up the front of the truck with the ramsey winch/bumper. I my self like mine, but it's just my .02
  9. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    I had the 4" rough country lift. The shocks were just fine to me. The lift wasn't enough thought. I went to the genuine suspension kit from 4wparts. I have the 6 shock kit and I love it. I get plenty of flex. The ride is a little rough, but I don't like my tires fully inflated unless I am hauling stuff. The springs work great for hauling too. I don't have a sway bar on my burb and I haul up to 6 cords of wood no problem with minimal squat and wander. She leans a little, but surprisingly not bad.
  10. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    They may have come out with a new line, but the ones I got would be considered rough by military tank standards!
    National Tire and Wheel-4" lift (ntwonline.com)
    Skyjacker with blocks-$354.00
    Suspension Connection-4" (www.suspensionconnection.com)
    Tuff Country-$249.00 800-505-5626
    Tyres International-4" (www.tyres1.com)
    Superlift-$299.00
    Hope that helps!! /forums/images/graemlins/peace.gif
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Thanks, Kerwin
    [/ QUOTE ]If you're at all concerned with ride quality, run as far and as fast as you can away from Rough Country. I really recomend Tuff Country or BDS springs in the front, and if your stock rear springs are in good shape, the the ORD Shackle flip in the rear. You can call the good people at ORD (970) 945-7777 and have them put together a complete lift kit with everything you'll need. Vist thier website to look at what they have to offer. Remember, cheap parts are cheep for a reson. In the long run you'll end up paying more when you replace those cheep parts with quality ones. /forums/images/graemlins/deal.gif
  12. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    i have some tuffcountry 4" up front and i bent them the fourth time out. and thet was just playing in the mud. i would consider it light wheeling. but ride was nice... still is just 2in shorter
  13. Chase
    Chase Registered Member
    Oct 23, 2001
    18
    i love the shocks i got um on my suburban
    /forums/images/graemlins/burb.gif
