4 inch shackel flip on CUCV Blazer tailpipe issues...
Discussion in 'OffRoad Design' started by Klink K5, Sep 1, 2004.
  1. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    Hey I want to put the 4 inch shackle flip on my 1986 chevy Blazer that has the factory stainless steel dual diesel tailpipe set up comming out right behind the rear tires. Is there going to be room for these pipes to stay there or do I have to wack them off. I would like to keep them there if I can in there stock location. Thanks, Klink /forums/images/graemlins/thumb.gif
  2. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    I put a 4 in flip on a m1009 & the exhaust was in the way.
    The tailpipes did have to be moved.
  3. Klink K5
    Aug 3, 2002
    549
    Northwest Iowa
    Well if the case is that I cant retain my factory Exhaust, I guess I will be doing a all spring lift /forums/images/graemlins/dunno.gif I really dont want to /forums/images/graemlins/hack.gif my exhaust off real bad.
  4. j20m715
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Its not like you have to redo it all.
    Its just the ends.
  5. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I did it on mine, just a little sawing, put in an extension. All done, real easy.
  6. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I did an all spring lift on mine and still had the cut off the tailpipes. /forums/images/graemlins/hack.gif
  7. Klink K5
    Aug 3, 2002
    549
    Northwest Iowa
    TTT. I think I am going to have the room, wolld like to know aqpproximatley how far the rear spring bolt eyelet goes down. I think their is room there fot the tail pipe above the springs. Thanks, Klink /forums/images/graemlins/thumb.gif Does anyone have pics of there shackle flip installed?
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The end of the spring will move down 8". The cleanest exhaust routing with the flip seems to be either extending or shortening the pipe to get it to clear the shackle. We have run into some that looked like they would have to be modified but still fit. There are lots of variations.
