4 inch superlift..drivetrain problems?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sanssocs2, Jul 5, 2001.
  1. sanssocs2
    sanssocs2 Registered Member
    May 9, 2001
    16
    Mobile, Alabama
    i am getting my 4 inch superlift put on my 85 blazer tomm and i was wondering if there will be any drivetrain problems? and also, i ordered the 36 TSL SX, they will fit right?
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I run a 4" Superlift on my 85 with no problems - I will advise you that if you haven't already, to add the ORD Frame Brace. 36's should fit - but you'll need to trim your fenders a little if you will be seeing any kind of articulation.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  3. Ross
    Ross Registered Member
    Apr 19, 2001
    75
    IL
    i just put 4" super lift front springs on my 86 blazer and the front drive shaft is about 2" short
    could just be my truck
    1986 white K5
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Alot of people have come up short on the frt shaft.... but others have been fine. I'd look into a 1" spacer from Superlift for it. Also you are really gonna have to hack those fenders to offroad w/ that rig... remeber those are a pretty true 36" not 33 or 34" like most MT 35" tires.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  5. jerseymudder
    jerseymudder Registered Member
    Feb 13, 2001
    59
    south jersey
    I run an '86, 4inch lift and 36.5x14. I tweak the susp. like a rag and I haven't had a problem. I also ran an '80 Burban w/36x14.5, No sweat(just my experience).
  6. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I'd imagine with 36in swamps and 4inches of lift you'd need some pretty healthy fender trimming. I remember reading in 4 wheel and off road about Cole's truck (the one they rolled down a sand dune) something like 6+ inches of lift, and his 36's would still rub the back part of the front fender when the wheels were turned.
  7. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    Coles truck had a 6" suspension lift, and a 2" body lift, and yes the 36s rubbed a bit. They added a 10" suspension lift and kept the 2" body lift to run 44s...I think they should have kept it 8 inches high with the 44s.
    <font color=purple>L8R...</font color=purple>
    <font color=green>chevy4x4
    </font color=green>
