4 inch sus lift and 3 inch body ?...?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Nov 27, 2000.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    hi i have a 77 k5 blazer and i have a 4 inch sus and 3 inch body with 35's on it right know but i would like to move up to 38 1/5 inch tires here soon will i have enought lift for those size tires and will i have to do anything like drivlines or anything ?...
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    in the new issue of four wheeler they have a lift kit/tire reference on page 48...for all the kits they specify 35"tires need a 6" lift and 38's and 39's need an 8" lift,,,so i would have to say you'd be cuttin' it close if they did actually fit!!!
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  3. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    You will need to do a little fender trimming...especially in the front. If you have 1/2 ton axles it's really pushing it so you should get 3/4 or 1 ton stuff if you don't already have them. the drivline angles only change when you lift the suspension. the axles are the same distance away from the t case evn if you have a 12 inch suspension lift and 31 or a 12 inch suspension lift and 44s.
    [​IMG]K5[​IMG]
  4. wheelin247
    Aug 29, 2000
    178
    hayward,ca
    so does it sounds like a good idea for my rig and yeah i still have 1/2 stuff but i will get 1 ton in awhile
  5. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Don't forget gearing. Just because a tire will physically fit doesn't mean thats all to be considered. The bigger the tires the more modifications you'll need. Bigger axles, deeper gears, and bigger brakes or at least rear disks would be a good idea. What gears do you have now?
    I've seen 38's and a 6" lift but the fenders were trimmed considerably.
    Rene
  6. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I have 4" susp + 3" body and 35s. I rub the fenders when its twisted up and I dont even have any big travel stuff done. My sway bar is connected, my shocks are stock locations, I run lift blocks etc. I have plans to cut the fenders very soon and still run my 35s so take it for what its worth... what kind of wheeling are you doing? If its straight line stuff without much articulation you will be OK. I ran 38,5s for about 2 weeks, and they fit ok for road, but I trashed a fender in the local trail entry thru a ditch.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
  7. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Just trim the fenders...the lift should be ok. My buddy runs 38's with a 4" lift and he had to hack his fenders real good for them to fit but he has no center of gravity problem and minor rub
  8. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
