4" lift 3" body lift 38'' tires what do u think??
Discussion in 'The Garage' started by ihatefords, Jun 11, 2006.
  1. ihatefords
    ihatefords Registered Member
    Nov 10, 2004
    28
    Wyoming
    I just put on a rancho 4" Lift and i had a 3" body lift, with a little fender trimmin can i clear a set of 38.5x15.5x16.5 Swamper TSLs. Or is that a good idea?
  2. bigdaddy
    bigdaddy Newbie
    Dec 8, 2005
    centennial, co
    It should fit them as long as you're not out thrashing. May have to trim alot in the front. Sawsall liftkit!
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I'm running 6+3 and had to trim to get good articulation. It would work for you as long as your not trying to do a lot of flexing.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    38.5 swampers will run a little small, so you should be able to fit them with a little trimming. it really depends on how flexy ur springs are.
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    x2
    I still have contact up front
  6. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    I have the same amount of lift and am sticking with 35's because I can stuff them pretty far into my fender well. Any bigger would rub. Just get 35" or 36" boggers.
