4" lift and 35's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lotsa_Faith, Sep 10, 2001.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    4\" lift and 35\'s?
    ok...around here, all we do is mud...no real flexing, except crossing ruts and jumping curbs really....whattaya do to get 35's under a 4" lift? who has that setup, and anyone got that setup w/bushwaker flares? and also, if i have 4" and 35's, would i be able to slab a 3" body lift on later and run 38x12.5" swampers w/out cutting more? what's the cheapest 4" lift? and also what other things will i need to get?
    Mike Dee
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Re: 4\" lift and 35\'s?
    I don't see how a 4" lift can fit 35's. I have a 3" and 33's and they rub
    90K5
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I've got a 4" lift and run 35s. I need to do some some fender trimming tho. I'm going to install some bushwacker cutouts. Seems to work ok. I'm also planning on a 1" body lift.
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Im sure you can run 35s under a 4"
    My friend runs 33's under his 3" body he is planning to get a 4" susp and run 38's.
    You might get some rub w/ 35's w/ the tiniest bit of flex though. You might wanna cut some fender just incase.
    38x12.5 seems kinda thin for the height dont it?
    6in 87' K5 w/ 35" BFG muds.
    Kn filter
    What I need: 4.11 gears, Lim Slip Dif, Force2 Catback, rear springs, some SSR's or SX's
  5. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    well i run 38.5s under my rig with a 4inch lift with some minor fender trimming and i DONT rub.
    350, sm465, NP205, 14 Bolt w/Detroit locker(465 ratio), yucky ten bolt,38.5 swampers
    <a target="_blank" href=http://www.planettribes.com/theden/gontw/nsig.jpg>http://www.planettribes.com/theden/gontw/nsig.jpg</a>
  6. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    [censored] i used tohave a 2in lift w/ 33s and NO rub
    now i have a4 in lift and 35's and no rub.
    also depends on the back spacing on the rims.
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  7. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I had a 4" with 35's on my 1979 Jimmy and I had no rubbing, But I mainly did dunes and high climbs, the tires only hit the fenders once on the dunes but I landed hard,LOL. It all depends on the rims, mine were only 7" wide, and mine flexed fine for what I needed it to do. The cut outs should take care of the problem if you have any rubbing.
    <font color=red>It's not what you drive, but what drives you</font color=red>( Or is it what you work on,lol)
    <font color=orange> 1955 willy's on a 1977 blazer chassis </font color=orange>
  8. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im running 33's with no lift and sagging front springs and I have minimal rubbing and only on the driverside which is the worse side. Im planning on 36's with my 4".
  9. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> 35's will fit with a 4" lift but to make sure there's no rubbing, I'd go with some fender trimming or a 2" body lift.
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  10. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    yeah i have 15x8 now [i think thats the width of stoc rims]
    then i am gettin some 15x10 w/ normal backspacing on them and i expect no prblems.
  11. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I had 35" BFG All terains with 4" of lift. I only rubbed when turning and flexing. With some minor fender trimming at the rear of the front wheel well, I had no problems.
    I don't think so, therefore I'm probably not.
    <a target="_blank" href=http://coloradok5.com/gallery/Frankenstein>http://coloradok5.com/gallery/Frankenstein</a>
  12. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    Have 35's with my lift, but I'm positive I could put 38's . I had 305/75/16's on 16x 9 rims, with my stock 94 burb with no mods and no rubs, (they are taller than 33's)
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear,(sitting next to truck) 12 bolt (still in truck) dana 44 front, TIRED ol 305----
  13. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i dont have any probs with my 4" lift and 35s but one thing to look at is the actual tire hieght. My general grabbers are only 33"s tall
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
