4" lift and 36" Super Swamper TSL's - QUESTION
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dj-beeker, Jun 14, 2002.
  1. dj-beeker
    dj-beeker Registered Member
    Jun 7, 2002
    13
    4\" lift and 36\" Super Swamper TSL\'s - QUESTION
    I am looking to add a 4" lift and 36" Super Swamper TSL's to my '88 Blazer.
    Will I have to do any fender trimming for daily driving???
    Thanks,
    Jeremy
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: 4\" lift and 36\" Super Swamper TSL\'s - QUESTION
    You will most likely have to do some trimming for like when your turning into a parking lot or something. Going four wheeling can be a whole different story depending on what your doing.
  3. Sinful_Nature
    Sinful_Nature Registered Member
    Jun 14, 2002
    90
    Raymond, NH
    I slapped a 4" BDS system in my 82 Chevy K10, with 36/12.5 Swampers with out any body trim required. Although I am still running the swaybar and the 2" Body Rust may be a factor.
    I've heard of some guys needing to trim a little off the corners in the front.
    ~ Russ
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I ran this combo on my 82 K5. No rubbibg on the street, but it was really close. No way would you be able to go offroad without some trimming.
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I am run rough counrty 4" with 36x12.50 tsl sx's and I did not cut my finders, I just beat the sh!t out of them with a BIG F*CKING HAMMER. Go to my webshots account to see
  6. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    for daily driving with the anti-sway bar attached, you prolly wont need any trimming... for anything else, you'll need some.
    J
  7. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    My friend "muddysub" runs this combo. On the street he would rub sometimes coming into parking lots. We then trimmed them and he doesn't rub at all on the street. We went muddin and it would rub occasionally. Look at his webshots. It has the pics of the trimming and IMO and many others it looks much better with them trimmed.
  8. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i have this set up and i would rub going into parking lots too fast. /forums/images/icons/shocked.gif /forums/images/icons/frown.gif i trimmed some and i'm fine now. i'm thinking of going to 6" springs soon though. or a 3" body lift.
  9. 88jimmyoungowner
    88jimmyoungowner 1/2 ton status
    Nov 20, 2001
    425
    georgia-rome
    would a two inch body lift solve this problem? that is the set up that i want, but i donmt want to hack the fenders
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You'll need more than 6" not to rub with no fender trimming and 36s. I'd bet you could even make them rub with 6 + 3 if you didn't trim with the swaybars disconnected.
    If you want a trailer queen, lift it 8-10" to run 36s, otherwise, cut your fenders.
  11. outlaw612
    Feb 11, 2001
    2,342
    It might, buy if youre gonna do rocks, it will probably still hit. Mud and trails will probably be OK.
  12. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    Trimming fenders is so much fun! No I'm not joking. Just do a little at a time, because you will wan't to trim more. BTW my rig has 35" BFG Muds with 1" ORD body lift and about 1.5" of suspension lift. I rock crawl and my tires do not rub. I'm just whishing I could find some more sheet metal to cut off.
  13. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I have 15-35x16.5 TSLs on 9.75x16.5 wheels with 6" springs. It comes real close to the rear of the front fenders at full turn, definitely would hit off-roading.
  14. muddysub
    Jun 23, 2001
    10,451
    489
    i'm seriously thinking about 6" EZ ride fronts and a 4" flip with 2" blocks in the back. and an ORD 1" body lift.
  15. dj-beeker
    Jun 7, 2002
    13
    It's going to be mainly used for extremely casual driving and possibly pulling a boat.
    If I can find time to 4wheel it might be trails - no rocks - not yet anyway.
  16. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    It shouldn't be any problem at all. For the street, just keep the swaybar connected and turn the steering stops all the way out so that turing a corner becomes a 3-point turn. For off-road, simply unbolt the swaybar, front quarter panels and inner fenders. With this weight left behind, you will wheel better, not experience any rubbing and enjoy lower underhood temperatures. /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif
  17. fbsadmin
    fbsadmin Registered Member
    May 28, 2002
    12
    I have 36" Swampers on my 1-ton with a 6" lift. My front tires rubbed on the backside of the fender openings when articulating even the slighted bit. They were fine on pavement, but as soon as I hit the trail, trimming was in order. All I did was trim off a couple inches angled back from the top. It looks quite natural since the crome molding was put back on and covers the sawsall cut.
