4" lift and driveshaft question
Discussion in 'The Garage' started by la_blazer82, Nov 29, 2004.
  1. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    4\" lift and driveshaft question
    I've installed a ORD flip with stock springs and a 1" zero rate on my 82 K5. 4" TC springs and 1" zero rates will go up front. Will I have to drop the t-case for driveline issues? If degree shims are needed, where can I buy some, and how/where do they go installed /forums/images/graemlins/confused.gif
    This is my first attempt to swap axles and install a lift myself. No previous experience.
  2. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    Re: 4\" lift and driveshaft question
    why not get the degre you need already cut in the zero rate tonyp on the socal site sells them.
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I had to drop my tcase a good inch or so. My rear lift blocks are degreed a bit but did not help. My driveline would start complaining, real loud, upon deceleration. Tried lots of things but the only thing that worked was dropping the tcase...
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I bit the bullet and got a CV shaft , but then again I drive mine to work everyday /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  5. la_blazer82
    Apr 12, 2004
    148
    SoCal
    Already installed the zero rates I bought from ORD.
    What did you use to drop the t-case, washers??
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    you can use the little spacers that are on top of the frame but it is better to use like a 1" piece of square tubing so that it spreads the stress /forums/images/graemlins/waytogo.gif
  7. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    I did what 85mudblazin said with the spacers...
    pauly383k10 - I did the same thing and purchased a cv shaft. I put it on and it vibrated like crazy... I took it back and they rebalanced it... It was better but still vibrates... It has been sitting in storage for a couple years now /forums/images/graemlins/angryfire.gif
