4" lift and steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GA89K5, Nov 2, 2001.
  1. GA89K5
    GA89K5 Newbie
    Oct 29, 2001
    4
    GA
    4\" lift and steering
    I just got finished puting a 4" rough country suspension lift on my 89, When I went to drive it, it would turn fine to the left but would not turn to the right. I put the new steering arm on as well.
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Re: 4\" lift and steering
    Sounds like you need to adjust your drag link.
    '85 K5 : Run it til it breaks, then fix it and go again!
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Have someone sit inside and crank the wheel back and forth while you watch the steering linkage. Will the wheel turn to the right but just not turn the vehicle? Something to watch for is the axle moving back and forth under the leaf pack. If you didn't tighten your u-bolts well enough, this will happen. When you go to turn right, the drag link pushes toward the rear of the vehicle. If the u-bolts aren't tight enough, the axle will actually move towards the back with the drag link instead of the axle staying put and the steering arm pivoting.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  4. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    Lengthen your drag link.
    '79 K5, '79 Suburban, '76 Br**co, 77 K20
    '99 BB 4x4 Suburban to tow more junk home
  5. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    137
    Rhode Island
    I've got the same problem. Same Rough Country 4" lift w/ raised steering arm. I looked underneath it just now and it looks like I need a longer draglink. Where can I get one?
  6. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    you dont need a longer drag link. Just adjust the one you have. Loosen the bolts on the clamps at each ball joint and use a pipe wrench to rotate the center section. One of the ball joints has reverse threads so that one way will lengthen the whole thing and the other direction will sorten the whole thing.
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  7. 78Jimmyish
    Jul 28, 2001
    137
    Rhode Island
    Sounds good man, I'll give that a shot tomorrow. How do I know how much to move it? Or is it just trial and error until I get it right?
  8. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i had that problem just lengthen your drag link and it will be corrected. but you have to do it right not too much.
    SWAMPERS RULE!!
    scott,
    1989 GMC suburban 3/4t 4" lift finally rollin on 36" swampers, tbi350, th350, np241
