4" lift/ driveline
Discussion in 'OffRoad Design' started by **DONOTDELETE**, Feb 21, 2001.
    4\" lift/ driveline
    i got a 4" lift but my driveline came out about 1" i was told to loosen everything and tilt the axle and tighten everything up again another person told me to extend my driveline which is the best way to go can anyone help
  1. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Re: 4\" lift/ driveline
    You should be ok, but if your going to do something then I would extend your drive shaft. I really dont think loosening up your axle then tightening it back up is going to change anything. As a matter a fact the person that told you that is nuts. Another thing you might think of is shims which pivot the angle of your axle housing, this wont make up for the entire inch lost but will help somewhat. One more thing you might think of is dropping down your t-case which will also help on the lose of the inch. But keep in mind that for the smoothest ride of your vehicle you should keep the angle, of both your t-case and rear axle, parallel in other words at the same angle.
    Michael
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Another option is to purchase Superlift's 1" driveshaft spacer part no. 4310. It's basically a steel spacer with four grade 8 bolts and lock washers. You install it between the flange at the t-case end. It costs about $40.00.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    That's pretty good advise above. try one of the drive shaft shops with websites for some more shaft info. I like Tom Woods Custom Shafts, www.4xshaft.com
    Another to try is high angle driveline, I don't have their url right now, but a search would find it.
    Making the world better, one truck at a time.
    SW-ORD
  4. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    <A target="_blank" HREF=http://www.highangledriveline.com>http://www.highangledriveline.com</A>
    Jeff427
    <font color=red>Mud Dog Off Road Club</font color=red>
    <A target="_blank" HREF=http://muddogoffroad.coloradok5.com>http://muddogoffroad.coloradok5.com</A>
